Question about Sony RDR-GXD360 DVD Recorder
Dvd will not play on other players after finalising
Hi,I have a sony DVD recorder, RDR-GXD360. when I record to disc DVD-RW and finalise the disc it will not playback on any other players including my computer, can you help please. Thank you.
4 Suggested Answers
SOURCE: sony rdr-gxd360 the now and
player will not stay connected to freeview channels
Posted on Nov 04, 2008
Beelz
  • 666 Answers
SOURCE: I own the sony dvd
if the disc no longer loads on your computer with the data it was suppose to have been written too it may be a finalizing error and you would want to make sure you have all the updated drivers and are using compatible software for it. If after burning the disc it is not being read on other dvd players and is not being read by your own dvd drive on computer or player than it is definitely a hardware problem and will most likely need to be replaced or returned if still under warranty
hope this helps
Robb
Posted on Sep 05, 2010
Sebin
  • 712 Answers
Does the DVD work fine on your computer and have a problem only when it is put in the DVD player?
Posted on Sep 09, 2010
Initialising and finalising dvd -rw disc
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Mar 30, 2015 | Televison & Video
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Dvd won't play on another player
if you are using dvd-r/rw discs they need to be finalised to make them compatible for other players, if dvd+r/rw then the other players may not support them.(dvd+ does NOT need finalising)
Apr 07, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When I record a dvd on my vr375 it will not play on my DSE dvd player .I am useing a Sony -RW DVD
before the disc will play on other players, you need to "finalise" the disc. Finalisation ensures compatibility with other devices. Go into the "Setup" menu, and look for "Disk Manager", there will be a finalise option. select the option, and after approx. 3mins the disc will play on other players.
Jul 18, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
When I record on DVD +RW disc from my other Tv and try to play it on my combie tv ,it will only play if my disc is finalised. so if I only record 30 mins and have to finalise ,I am wasting the disc. Why...
Some tv's are not capeable of reading Rewritable disks. By finalising the disk you are basically making it a non re-writable and thus allowing your other tv to read it.
Jul 16, 2009 | Televison & Video
Recorded movie on dvd-rw will not play on another player
the best format to buy is the DVD-R but make sure your disc has been finalised if you reinsert your disc on the functions screen you should see finalise this is essential for compatible playback hope this helps regards Jim
Mar 26, 2009 | Televison & Video
Wont play on other players
Here's the link to the manual; http://esupport.sony.com/perl/model-documents.pl?mdl=RDRGX315 check page 67 - it sounds like your discs need to be finalised before you can read them elsewhere Hope this helps, if you dont find what you need please ask again :)
Apr 10, 2007 | Sony RDR-GX315 DVD Recorder
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Sony RDR-GXD360 DVD Recorder Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
