Question about BenQ T2370 Notebook
When clicking the auto adjust button, the screen shrinked.
I have a benq T201WA 20'' monitor and one day i was meant to decrease the brightness when i accidentally pushed the auto adjust button which searches for ideal size and all that. But when it finished my screen was smaller than before. There is a wide black space between the right edge and the screen itself.
I cannot do anything in the monitor settings what will fix this.
Also, the text is a bit warped and fuzzy at some points mainly because the screen is smaller than it should be. And to be clear the screen shrunk from the sides of the screen, and not from the tops.
  • jerkslope Dec 31, 2008
    I have tried pushing the auto adjust many times after it did this but it just stays the same. I can move the active screen from side to side but there is an about 2 inch black space between the edge and my active screen and this happened after i auto adjusted.
    And yes it is an LCD monitor.
  • Anonymous Mar 01, 2009
    Sorry, you solution isn't working
    Master:
  • 413 Answers
If it is an lcd monitor make sure the refresh rate is set to 60hz and the resolution is at least 1024X768 then try to push auto adjust again. To get to the refresh click on the advanced button when the display properties is open.
Posted on Dec 30, 2008
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
Mar 28, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
MY SCREEN IS TO BRIGHT
On your monitor there should be a dial or button that you can use to adjust the brightness to your satisfaction. The icon is usually represented by an image of the sun.
Hope I helped
Nov 27, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
Computer monitor keeps auto adjusting screen
I have a Benq that was continually auto adjusting, I used electronic cleaner spray on all the controls (a good spray) and now there is no problem, suspect the controls were sticking, especially the on/off and the auto adjust button
Dec 20, 2008 | Computers & Internet
Acer fp 855
Hi Dean,
Open your on screen display, used the +- buttons to go up & down. In this case used the - button to find the brightness setting. When you see reached the brightness setting press the first button ( the one you used to open the on screen) to activated the changed. Now used the + to adjusted the brightness to your desired. Well, hope i can help you on these. If not just give yourself a new LCD monitor for Xmas. Now a days...it's only cost about $200 for a 20" widescreen. Have a nice day!
Oct 03, 2008 | Acer Computers & Internet
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Wide screen problems
I guess the video board or logic board is having problem.
Apr 24, 2008 | ViewSonic VX1935wm LCD Monitor
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Jan 04, 2008 | Dell M782 Monitor
BenQ T2370 Notebook Logo
289 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
