Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Snapped cable input
So I snapped off the cable input on my RCA 52" rear projection. I am new to having a big TV like this, so I'm not sure whether this is a problem I can fix myself, or one I need to have a professional repair. I think I can pull the panel off the back of the TV to access the cable input, but I am not sure. I assume this piece is replaceable. I am hopeing someone out there might know. Taking this TV to a repair shop will be a big pain in the butt. Any help would be appreciated. Thanks. notfop
  • dsrogers Dec 14, 2008
    I also have a snapped cable input problem. Upon taking the back off of the unit, I found that the piece is actually inside a small silver piece and not soldered directly to the main board
  • 105 Answers
It all depends on what actually broke. Those input connectors are usually 90 degree metal units, soldered to the circuit board, so possibly the connector took a chunk of board with it. Any competent TV technician should be able to repair this in your home, especially if you tell them what the problem is when you call them. That way they will know what parts to bring.
Posted on Jul 17, 2007
Mitusbishi WD-52327 tv cannot figure out how to get the digital cable box to come on screen?
Connect RCA wires (yellow, red, white) from the box's "out" to the tv's Input 1 or 2 on the back input panel of the tv set. If you don't have RCA's you may use a RGA- jumper wire (cable wire made into a 4 ft segment by the tech or buy a short cable wire from the Walmart, Target, or Goodwill store) Connect this wire to the "cable in" on the tv and the other end to the "cable out" on the box.ADDITIONALLY make sure you have the right input settings selected on the tv with the input selection you make with the wire connection you choose.
Jun 21, 2012 | Mitsubishi WD-52327 52" Rear Projection...
REEPLCE ANTENNA INPUT ON D52W19 RCA PROJECTION TV
Often they can be soldered back onto the tuner. But the tuner itself may need replacement which you can get tuners and the entire SSB which has the tuners already on them from www.tvrepairworld.com
Dec 18, 2011 | RCA D52W19 52" Rear Projection Television
AWe are attempting to play PS Three, but the Inputs on the front and back of tv for the RCA cables arent working. What should we do to make the inputs work?
change the input, i have the same configuration ps3 and 52 inch rca, just plug it into front and change the input to front, if that dont work try this, since your ps3 probably came off a tv that had hdmi you need to hold down the ps3 button for 9 seconds and it will ask you if you want to change it to lower settings, but first make sure you have the input right
Sep 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model d52w23 coaxial connect
Some of those models were actually just big monitors without any on board tuners so They didnt have any need for coax cable inputs. You most likely have one of the monitors.
Jun 26, 2010 | RCA D52W23 52" HDTV CRT TV
Last night I bent the (cheap) yellow input cable a little too much and the stressed cause the cable to snap off inside the tv. Any suggestions on how to get the piece left inside the tv out? For a quick...
If your cable box has the red, green and blue component outputs that would work good as long as the TV has component inputs. Other than that you could use the side yellow input.
Oct 16, 2009 | RCA D52W19 52" Rear Projection Television
Hookin up local cable
The input from the outside line goes to a two way splitter ( input ) then to each of the two sets on the output of the splitter.
Mar 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Rca d52wi5 tv tuner replacement
i have noticed that the new tuners are missing a few pins. i believe that it will work. what is the exact make and model of the set there is a tiny printing of the model above the model # i has d52w15...yx....something. you need this to cross reference the tuner. let me know and i will cross ref it
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
