Question about Motorola Mobility RAZR V3x Cellular Phone
I CANT STUDY
WHEN I START TO STUDY I FEEL BORING EVEN IDONT LIKE TO OPEN THE BOOKSO I CLOSE THE BOOK AND NOT TRY TO OPENE IT UNTIL THE NEXT DAY / WHAT I CAN DO TO STUDY HARED? I HOP YOU CAN HILLP ME
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
If you feel you cant study, then probably you are in one of the toughest times of your life.You have to come out of this situation, you have to be more peaceful in life.You might be stressed right now.You can do it, you can do wonders, but you should first have the confidence for that.Only when you start believing in yourself, you can start doing things, different from others.Life will not be easy always, so just realize that, this is one such time of your life, wherein you have to be more focused.You have to gain more precision, about what exactly you need to do in life.Life will become beautiful, only if it lived in such a way that it is well planned.If the very thought of the books, irritates you, then take a break for half an hour, Think about yourself, you dear ones, and why exactly you want to study.The purpose if know, will make a great impact on you.Yes, you can do it.Raise above from this darkness of your life, and bring in more light into your world.Light up your life with your wisdom.
Posted on Nov 16, 2017
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
You need to get your chit together. Get away from all distractions and study for half an hour with a ten minute break and then another half hour. YOU need to apply yourself nobody can do this for you, there are no magic pills or answers, just get off your duff and stop looking for someone else to fix YOUR problem on this,
Posted on Dec 31, 2008
Myunisa login
Well then, wait for the library to open. I feel your anxiety when the place is closed. Try the Internet or wait until Monday when it opens.
Mar 11, 2014 | Computers & Internet
07 Convertible
This is easy, first locate the top button on the center console but do not push yet, next the lever on the front off the top, reach your right hand up and grab lever and pull down and twist counter clock wise to unlock it, you may feel roof pop up a little then with roof unlocked push handle back into its slot, next is push button and hold, the roof will start to open and the trunk will start to open and the roof will store away i the trunk,, make sure trunk is empty at first use, then with the top down and trunk closed you are done, open the trunk just to look inside to see where the top goes, this is to make sure nothing gets in the way of the roof, i cant remember if area is blocked off or not but this is a good idea just so you know.
To close the roof you hit and hold the button and roof will come out of the trunk area automaticlly the roof will end up closed all you do is pull lever down then pull on lever to close roof all the way untwist lever and it will go into lock, you will feel this, once it is in the lock groove you will twist lever to the right to lock it, with it locked you then push lever back into its slot. good day
May 06, 2012 | Cars & Trucks
Changed the master cylender and vacuum booster and blead the system by the book and still cant get breaks without pumping them.
There must be air in the system some where. i am not sure of the year ,make and model of this van and also not sure of the brake system, for example if you have drum brakes in the rear then first adjust them.
The next step is to fill the master cylinder, make sure there are no leak anywhere.Next step start at the master cylinder, at the line to master do not worry about abs system. have someone inside ready to pump brake pedal and hold.Have them pump pedal three times and hold pedal with a little pressure.make sure as you open the bleeder they push on pedal and keep foot on brake until you tell them to pump again. the pedal is to be pumped three times every times.
With pedal pumped start at master lines, open one allow to bleed a little then close and move to next and allow to bleed. if master has more than two lines then pump again and do two, open one and close then open two and close then pump again. After master is bleed a few times and no air comes out then move to right rear wheel, pump three times and hold while you open bleeder, this is to be done about four times to make sure you get a good flow of fluid with no air .
NOTE: always keep master cylinder full, check after each wheel. make sure the person pumping the brakes does not lift until you say and the bleeder is closed. After the right rear wheel you will move to left rear and then right front wheel and last is the left front wheel.
Make sure there are no bad wheel bearings, lift wheel of the ground and grab and check for movement by pulling wheel out and in from top to bottom, the last thing is make sure the caliper slides are free moving.
If the caliper does not slide on the bracket freely then the piston will not stay on pad and pedal will need to be pumped to get a pedal. good day.
Mar 11, 2012 | Cars & Trucks
Gas pedal sticks/hard to push when first starting to drive. after that it is normal.
You need to clean the throttle body plate and bore area.You can get throttle body cleaner at your local parts stores.Just remove the air cleaner and the boot that goes to the throttle body and hold the throttle open.Take a rag and soak it with the cleaner and start cleaning the bore and the throttle plate til the tarish stuff is gone.You should be able to feel the plate not stick by moving it by hand to the open and close position.You can also spray it down with the cleaner before you wipe it with the cloth.You can use brake cleaner but then it takes longer to clean and you have to rub harder.Throttle body cleaner works the best.Hope this helps.Good luck.
Feb 26, 2011 | 1995 Pontiac Bonneville
I have no ides how to reset the laptop as someone has taken everythin off the laptop the laptop is a acer 5315 really need some help cant even get the disk drive to open
Take a Norwegian paper-clip, and straighten one end.
Insert that end into the small hole in the faceplate of the CD-drive,
and push until you feel resistance.
Then, push another 1/4 inch (6 mm) to "unlock" the drawer.
Then, push the open/close button, and the motors should push the tray completely open.
Then, insert the original Acer "System Restore" CD, close the tray, and restart your computer. Tell it to boot from the CD.
When it does, it will start to reinstall Windows.
Oct 24, 2010 | Acer Aspire 5315 Notebook
It starts and runs but when you turn it off it won't restart.
I think the warm start procedure in the manual is causing it to flood. Try it like this, if you continue having problems reply below and we will try something else. PLEASE read #3 (Cold and Warm) a few times before attempting to start. Try it without 1/2 choke (your manual); completely open.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed or at 1/2 choke position.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Hope this helps.
Lou
Feb 21, 2010 | Poulan Garden
Cylander keeps filling with gas when trying to start
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
OPEN THE CHOKE
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and LISTEN for an attempt to start. once heard (usually two pulls)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
Hope this helps
Lou
Oct 28, 2009 | Garden
Hartd to start when saw is warm
Are you choking it? You shouldn't be if hot. If no clean the air filter and try again. Are you setting the fast idle? You should be. Better? If your start procedure is similar to below and your fuel hoses have no cracks or holes the carburetor needs adjusting. A tune up might be a good idea. About $40 at your friendly neighborhood Stihl dealer (regardless of make). If taken in for tune up, get the oil/fuel ratio and use it until your next tune up (regardless of what manual says). HTH
Lou
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Warm:
Hope this helps
Lou
Oct 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Web cam
maybe your infected by virus.Try system restore to the earlier time before it happens.
jomski
May 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
DVD Drive opens automatically when I start up the pc and won't recognize disc
Mary, there is no quick easy solution which will not invlolve your getting your hands "dirty" a bit. Try uninstalling the drive in your computers device manager first of all to see if after you do this and reboot your computer it is still opening, if it is it is an issue with the drive iteself NOT with windows. If the drive has malfunctioned in this manner replacing it is your best alternative but you can TRY this...
In the front of your drive should ( should ) be a little hole near the eject button under the cd tray, it is just right for putting a paper clip which has been straightened oout into it. Try pushing a paper clip into it untill you feel it hit something. What you feel there is an emergency eject button, with pressure on this button try to "cycle" the drive by hitting the eject button and holding in pressure on the paper clip. Hopefully you will reset drives tray to reverse its order. Good Luck
Feb 11, 2008 | Panasonic (SW9585C) DVD±RW Dual Layer...
Motorola Mobility RAZR V3x Cellular Phone Logo
183 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
