Question about Audiovox Xpress R XM Satellite Radio Receiver with Vehicle Kit
My Audiovox Xpress R won't connect to radio via FM Modulator
Everything (I think) is connected properly. It was installed by a professional.
The Audiovox Xpress R will not connect to my new Kenwood car radio via the FM channel. I have changed the fm modulator channel, but it still won't work.
Help !!! I hate listening to regular radio with all those commercials!
Thanks
  • fallwater08 Apr 20, 2009
    I have the same problem, except my antenna connection isn't working either. It just says "CHECK ANTENNA" 99% of the time, but when it does work for maybe 5 minutes then the FM Modulator won't find the signal. It's bizarre.
natenash7986
  • 53 Answers
SOURCE: Don't have all the channels on my Audiovox Xpress R
i would send the unit back to where u got it. i have ran into this before and the unit was sent back to xm and they replaced it call xm and see what they can do for you
Posted on Aug 07, 2008
kevin000
  • 1847 Answers
SOURCE: FM output
The low signal may be due to loose connection of the antenna cable
Posted on Aug 29, 2008
SOURCE: FM output
I had the same problem. Only thing that I came up with that was consistant is plugging it into the aux jack on my radio so you don't have to depend on FM frequency. But, my unit crapped out this week and I hope it is under warranty.
Posted on Sep 23, 2008
SOURCE: No Signal on my XM Radio
Lately I have been loosing the signal constantly in the house. I've tried different stations to see if it would be any better and it's not. I called xm and they refreshed my signal but it didn't do ant good. It's really annoying to constantly have the signal fade. Everything is hooked up right. This is been going on for about 5 months and my neighbors complain about the same thing.
Any Suggestions
Posted on Mar 13, 2009
glennsimoes
SOURCE: I get no audio from
The antenna wire was broken on the back of the radio.
Posted on Apr 30, 2009
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
FM output
Aug 29, 2008 | Audiovox Xpress Satellite Radio Receiver...
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
How to get the dvd player to play threw my truck speakers?
if you dvd play came with a wireless fm modulator read the owner manual and set up the fm station to get it to work . if it does not have a built in fm modulator you need to buy one.
the pull out your radio and run power to the fm modulator and then connect the factory anntenna to one side of modulator and the other side goes back to your factory antenna location at radio . then set the fm station you set for the fm modulator run a set of rca cables from the fm modulator to the dvd flip screen and it should work . i would think your flip screen dvd play would have a built in fm modulator that is wireless .
caraudioquestion@gmail.com
Oct 28, 2010 | Insignia Mobile DVD Player with 9.5"...
How do I install :Audiovox FM Modulator EA FMM100A? I have a 2007 Nissan Versa S hatchback. I already know how to take out the radio. What plugs into what?
you should only have two wires red which is power and black which isground then all ya do is plug the antenna into it then tune the radio into it
Aug 08, 2010 | Audiovox FM Modulator EA FMM100A
Chevy Impala delayed starting after removing radio
no this is not a radio problem. disconnect your aftermarket acessories and plug your radio as it was from factory and see if u still have this problem. there is probably a problem with communication because of your fm modulator or your ipod. radio does not cause a security problem on this year vehicle
May 05, 2009 | 2005 Chevrolet Impala
FM Modulator Installing to 2001 Honda Accord need +12ACC power wi
use a wire tester.. if ground the tester and poke the wires till you find a hot one.. then just simpley hook into that wire..good luck keith...
Mar 15, 2009 | 2001 Honda Accord
Sportster 4
Shouldn't need one. Does the rear antenna connect to the direct FM box?
Aug 30, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Open Questions:
Audiovox Xpress R XM Satellite Radio Receiver with Vehicle Kit Logo
111 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
