Question about Canon Pixma iP4500 InkJet Printer
Ink not working
I have just reinstalled the ink cartridges on canon ip4500 but it is still not printing. i think it is only one of the black ink cartridges that isnt working but it is printing really faded and lines missing. help!
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
Canon Pixma iP4500 InkJet Printer problem: The printer seems to be working ok (no errors or warnings) and it prints documents well but is leaving a black streak on the underside of each page. I have tried...
Use warm water and a lint free cloth and clean all the ink around the cartridge area. I f that doesn't help I would try a new (not remanufactured) ink cartridge.
Jun 28, 2017 | Canon Pixma iP4500 InkJet Printer
I have cleaned and deep cleaned the printer a number of times but when I do a print check the yellow line does not print neither does the black line under it print. When I print anything else the yellow...
If a line doesn't print, the ink is out of the cartridge for that inkjet cartridge color. Replace the cartridge. Deep cleaning can use a lot of ink up at a time.
Nov 11, 2010 | Canon Pixma iP4500 InkJet Printer
Hi, My printer says it wont print. the cartridge light is flashing On top it says Pgbk (On the screen it says PG1-SBK The remaining f the following ink cannot be correctly detected - black. What do I do?...
some printer s have timer chips in the ink cartridges i have new epsom cartridges only used once now wont reconised due to the chips you may need to replace cartridge you could try removing the cartridge and reinstalling it to make sure it has good connections
Jan 17, 2010 | Canon Pixma iP4500 InkJet Printer
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
Canon iP4500 not printing yellow
take the print head with all the cartridges still installed out of the printer. take a soft microfiber cloth and gently wipe the exposed surface on the bottom of the printhead. You should get some ink to wipe off the printhead.. reinstall and retry your printing.
May 31, 2009 | Canon Pixma iP4500 InkJet Printer
My Canon iP4500 does not print with "black" cartridge
hi im josh in cebu phils. may i help you? Friend the problem is your cartridge and on the tank lever.it causes spoiled ink that stuck on it. To solve this problem. you may visit the Cannon Pixma support manual site and follow the steps there:here:
http://www.generalmanual.com/Printers/Canon-PIXMA-iP4500-Photo-Printer.htm
good luck friend hope i helped you.
Mar 14, 2009 | Canon Pixma iP4500 InkJet Printer
Hi I Have a Canon IP4500 and have fitted new inks however error message says an ink tank error has occured.Open the printers cover and replace the ink tank on which the ink lamp is off. I Have tried...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Jan 26, 2009 | Canon Pixma iP4500 InkJet Printer
Canon pixma ip4500 print head problem 5 lights flashing. Reinstalling print head does not solve problem.
Printhead can be washed under running hot tap to flush all the old ink away. I did mine and it didn't affect performance after drying it overnight in a warm area. Re-fitted it and away it went. Don't worry about getting connector board wet at the back.
Apr 17, 2008 | Office Equipment & Supplies
Canon Pixma iP4500 InkJet Printer Logo
269 people viewed this question
old marine
old marine
