Question about SMC EZ Switch SMCGS24 24x1000 Mbps
Sonicview 360 Elite
I purchased a 360 Elite 12/11/2008 , the box worked for a few day and I was trying to use the dual tuner feature and I went into the menu and copied the Turner 1 to tuner 2 feature and I turned off the box from the back and when I turned it back on I'm not getting any picture, USB, nor does the remote work, when I turn on the box I get Boot main then 6 then it stops on an upside down (U) symbol, I went to your web site and down loaded the Factory bin and when I installed it , it says complete and the box says save then S then A then E and then back to the upside down U symbol , also I tried a hard boot holding the ok button still no luck, is there anything else I can do
  • Anonymous Mar 28, 2009
    same problem
2 Suggested Answers
  • 10 Answers
SOURCE: Sonicview 360 Elite Dual w/ Dish500dpPLUS EXC! signal cant watch!
Have you resolved this issue and do you now have a ihub for you SV? Since they went IKS and have no stand alone fix, it is difficult to get modded signal. However they are still in the beta phase of this fix and are have some freezing issues. But is you stay with them until they fix this, the you will be fine. Another solution is the ilink or the nFusion STB's. They are proven to be stable for now. Good luck. I am currently testing ilink, nfusion Solaris Prem and HD, SV 360 & HD. Anything I say here is for testing purpose only and not meant to be a solution for a mod fix. As a FTA user, you will understand what I mean.
Posted on Oct 02, 2009
What sonicview 360 Elite pvr remote code?
0018,0019,0014,0011.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 19, 2014 | Sonicview Universal Remote Control for...
My Rca 52 inch has lost color But If I set the feature
PIP means the set uses either two tuners or a dual tuner--could be a issue with the tuner. If it has a swap feature in the PIP use it to see if color when tuner is switched from main to PIP tuner.
A possible way around the issue is to look to see if rear audio/video inputs have color---you could route signal from a box etc to one of those and BYPASS the problem if rear inputs do not have this problem(not likely they will).
Jun 15, 2012 | RCA HD52W59 HDTV Projection Television
I purchased an xbox 360 arcade 2nd hand, then purchased a bunch of old games that don't work on this model. i then puchased a 250gb harddrive but am still not sure how to update the console to be able to...
Who exactly is "They"? By my understanding, the X-box 360 Arcade is NOT backwards compatible, meaning it cannot play original x-box games. The only one i know of that can is the X-Box 360 elite.
Now then, if you go online to the X-box live Marketplace, they have quite a few original x-box games available for download, but you have to pay for them :( These downloaded versions WILL work with the 360 Arcade
Aug 08, 2010 | Microsoft Xbox 360 Console
360 cannot read Resident Evil 5 games...two different ones!
It's more than likely the DVD drive. Try a different game or 2 to be certain. If you are still getting that issue try running a CD based cleaner a few times. If that doesn't solve your issues contact Microsoft as a recently purchased console should be fully under warranty.
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
My plasma does not split screan to show two channels (input) from the video recorder.
Correct. It doesnt. What are you trying to accomplish? If it is PIP from a cable box this needs to be within a dual tuner cable box. This has nothing to do with your TV.
Any TV that can do PIP has dual tuners.
Dec 01, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
No signal on one tuner for dual tuner box.. neither tv works.
Hi benray there is something else youcan do on that to make sure your getting the strongest signal possible. Youwill need to press the MENU-6-1-1 buttons on the remote. Select Check Switchand Test, after the test is complete select done and then check the signal andif there is still a weak signal we will need to re-point the Dish.
Oct 24, 2009 | DISH Network 322 DTV Receiver
Adaptec AVC-3610 dual tuner only showing as single tuner in vista
To diagnose, try to make it work with a different computer. If it does not work, the problem is with your AVC-3610, else try uninstalling and reinstalling all the drivers and software that came with it.
Mar 27, 2009 | Adaptec AVC-3610 (2144600) Video Capture
You need to use a sonicview splitter and then go into your settings and select proper ports.If you have 2 wires comming from i duel lnb or 2 stats then you install then in the splitter then one wire into your reciever.then you scan the sats on the ports you have them hooked on to. example echostar110 port 1 also tp setting is 12258 Then echostar119 port 2 also tp setting is 12239 then scan. Scan on autoscan. hope i helped :)
Mar 01, 2009 | SMC EZ Switch SMCGS24 24x1000 Mbps
SMC EZ Switch SMCGS24 24x1000 Mbps Logo
247 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
