Question about Samsung SP42P2S Television
Could you tell me pls where the factory reset button is ?
RED GREEN BLUE CROSSES ON SCREEN T.V REPAIR MAN SAID NO GOOD ? ANOTHER SAID TRY TO HOLD BUTTONS TO GET ALL TOGETHER ? FAILING THAT PRESS FACTORY RESET BUTTON BUT CARNT FIND IT. PLEASE HELP.
Its on the side of tv! but 1st take on the black lable on the back than push that button in than the red green and blue will can on ones done put black lable back on and thats than good luck
Posted on Feb 11, 2009
Thomson STBDH1685P was working perfectly. I tried to change the resolution of the screen and now it wont work. Message reads Mode Not Supported. Cannot get Menu options. How do I factory reset.
hi not sure if this will work but you can still try To carry out a factory reset.
Menu
4 (set up )
6 (help )
then press the green button.
To restore the factory settings,then press the red button.
work but you can try it, thanks
shaun
Mar 23, 2017 | Thomson Televison & Video
Why when I turn on my zeepad screen is blank battery is fully charged the green man shows then blank screen?
Hi, try a Hard Reset!
Normally, you have to hold one of the volume buttons down while powering on the device(try them one at a time). If you get a screen that says something about download, try the other volume button.
Once the device has booted to the "special recovery" menu, this is controlled by one of the volume buttons to scroll through the options and the POWER button acts as an enter key. Be on the lookout for an option that says something about "restore factory settings" and select that!
Oct 18, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
I got a problem with my htc mobile, ie. how to restore my factory setting at HTC Snap S521
Try to hard reset your mobile it will store your mobile to factory setting.
To perform a hard reset
1. Remove the battery from the device to power the Dash 3G off.
2. Reinsert the battery, DO NOT power back on.
3. Press and hold the Volume Up button.
4. While continuing to hold Volume Up, press and hold the (red) Power/End button.
5. A multi-color screen (boot loader) will appear, continue to hold both keys.
6. The reset screen will appear (a grey screen with blue text).
7. Press Send to reset, then Send again when prompted to reboot the phone.
8. The device will reset and boot to the home screen.
Feb 15, 2011 | Cell Phones
Picture fuzzy and brighter in center. convergence good on red but blue and green only show in center crosses. green and blue glow around figures.
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair World.com,Tv Repair Kits.
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
The screen is red blue and green and says serial
hi
you might have a problem with side camera button. try to clean that button and make a reset.
the tricolor screen represent bootloader state.
to enter bootloader there's only one way on this device: reseting and holding the camera button.
if you can get out from this state, try making a clean boot, erasing all data and restoring to factory defaults:
press and hold the 2 action keys (the 2 buttons above the joystick) and make a reset with the edge of your stylus.
when message appears on screen, follow the directions.
Jul 29, 2009 | HTC Tilt 8900 Smartphone
Getting a red, green, and blue screen when trying to hard reset
your going to have to download a recovery.img of the stock rc29 system and boot that up from that screen. This will hard reset the phone and then from there you can upgrade back to your desired rom.
Jun 27, 2009 | HTC G1
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
HO board
CONVERGE PROBLEM
hello,
60pp9202 About 2 days ago tv went blurry -all colors separated!
I first tried factory setting convergence - NO GOOD!
Then by hand one cross aligned at a time (red mostly, and green, the blue doesn't show misalignment) , tv won't save my efforts after I shut it off.
The crosses around perimeter are bend like bows , so when you try to bring yellow and red crosses together to align with "converge red"- they can't line up because red and yellow crosses are bowed-bent opposite, in center they are closer to straight be still all are a bit warped! images on screen are now also warped as well! If there are any of you in the Queens nyc area that can come and do a good repair- I would be glad to pay a decent fair price! (917)687-6290 CALL ME IF YOU CAN COME TO FIX IT (2PM-8PM) ANTIQUEBABIES@AOL.COM
I WOULD ALSO APPRECIATE ANY ADVICE! CAN I FIX THIS MYSELF BY CHANGING A "SNAP IN" NEW PART OR DO I NEED TO DO SOLDERING AND HAVE TESTING EQUIPMENT AND SPECIFIC TV REPAIR KNOWLEDGE???
THANK YOU! KURT
Nov 08, 2007 | Philips 60PP9202 60" Rear Projection...
Samsung SP42P2S Television Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
