Question about NEC MobilePro 900 Handheld
My NEC MP900 won't sync!
I've tried everything, tried to find a solution in other forums etc. I'm beginning to think the usb port doesn't work. I bought this on ebay and have never been able to sync it. I don't get any communication between the device and activesync (3.8). Any help will be greatly appreciated!
  • Phil Sheridan May 04, 2007
    Thanks for your response! No, no sound,or USB icon - I actually don't get any response at all. I've installed the USB drivers, still nothing. I supose the port is cooked...
  • 102 Answers
First when you plug it with your PC.. do you hear the sound of the connection ? ... can you see the USB Icon at the system tray? Doest the system pop-up a message saying that the USB device isn't recognized? If it doesn't ! then there is no USB connection made... Try live support.. it's better to solve problems.
Posted on May 03, 2007
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
Ok, I have a Zhone 6211-I3-200 Bridge/Router or in other words a Paradyne ADSL CPE, and I cannot for the life of me get it to work with my Xbox 360. I used to have a different router and I would switch...
Zhone Modem Model #. 6211-13-200-0PA ADSL2 BRIDGE/ROUTER, AN.
I would like to upgrade current Firmware, but it is quite difficult and my ISP support even knows how to do this upgrade.
Nov 06, 2011 | Zhone 6211-I3-200 Router
I have an HP Laserjet P2035N that worked just fine until I moved it from home to my office. When I hooked it up to my laptop, which it has been before, it said the printer was offline. I've tried...
network printer is connected to check network connection. (cable, plug, etc.), if everything is ok not a problem to the network printer port on ferl can happen and if it is installed USB port, possibly connected to a another USB port
May 25, 2011 | HP P2035N LaserJet Monochrome Printer
I have a USB Cable connected to it but it says the printer is off line. I've tried different USB Cables and it just won't print. I'm lost please help me!
please assure the number of port USB in setting properties with your plugin the your lap top.
edy_bubat_4.jpgif doesn't changed, you can email me....
May 23, 2011 | Lexmark E332n Laser Printer
My new afterglow controller won't sync but turns on, it is wired.
If by not syncing you mean it flashes the whole ring when you plug the controller in the USB and won't identify? If so I think the problem may be that you have other USB devices plugged in at the same time. Unplug all the USB and plug the controller in by itself. I've had issues with this for awhile myself. I had a bluetooth and another wireless kb/mouse. So I unplugged everything tried it by itself and it seems to identify perfectly.
Conclusion: Unplug all the USB devices and plug the Afterglow 360 controller by itself and that should solve the problem. =)
Dec 01, 2010 | Microsoft Xbox 360 Controller
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
Sync to PC
I have had problems with that too, but i think i¨ve finally managed to overcome this. In setting>connectivity>USB connection menu choose Data Transfer/Service (I have Czech software, so excuse wrong names). Than Start LG Sync program, choose USB port and it should be working,
Although much more important problem for me is how to make built-in MP3 player play songs from external SD card without stopping after each song, not mentioning unavailability of other player functions.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
NEC MobilePro 900 Handheld Logo
188 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
