Question about Whirlpool Duet GHW9150P Front Load Washer
The washer is stuck on control lock
I have unplugged trying to reset and also held down two or more buttons at the same time and nothing is working.
  • hughesnuze Dec 31, 2008
    I actually fixed it before I saw this idea. I ended up pressing the "end of cycle" button and it cancelled the lock up. Thank you,
  • 640 Answers
Happy new year help has arrived...always unp[lug unit...at this time i cant tell you why it locked up,,but i can take you through opening manually,,ok just step by step...unplug uni...now lookdown at that bottom toe panel,,,remove 1/4 nut diver,,,slow now your going to reach up right under the door switch on the bottom of that assembly is atear drop tab just pull it,,,,,now the door is opened,,,
Posted on Dec 31, 2008
  • onthethejob1
    onthethejob1 Dec 31, 2008
    cool way to go,,,happy new year,,,
GE GDWT160R dishwasher.
Some type of dirt or dust got in your panel, now the contacts don't touch. Not a diy job.
Jul 27, 2017 | GE GDWT160R Dishwasher
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock will not turn off
the far right set of buttons lowest one, if you looked closely is marked "control lock" hold for 3 secs, the control light will go off
Oct 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Control locked
look on consoles for small lock emblem hold that button down 3-5 secs
Sep 01, 2008 | Whirlpool GHW9200L Front Load Washer
GE Washer WSSH300GWW front loader washer CONTROL LOCK!!
Solution: Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off. I think it is a problem in the machines firmware. I just guessed at what combination of buttons the engineers used to do a firmware reset. In any case it worked for me.
May 23, 2008 | Kenmore Elite 45986 Front Load Washer
Control locked
is any thing on or working check to make sure door is latched
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
