Altec Lansing inMotion® iM500 Docking Station for iPOD nano Logo
Lucas Pelster Posted on Dec 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IPOD WILL NOT TURN ON - Altec Lansing inMotion® iM500 Docking Station for iPOD nano
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Jan 17, 2009
Anonymous
Expert
Level 2:
Answers
64
Questions
8
Helped
36180
Points
131
Have you tried holding the menu button down for about ten seconds? Make sure the hold button is not on.
1helpful
2answers
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Ipod does not power up
Ipod wont turn on
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano. Hope this helps.
Dos not work
Reset iPod
hope this helps
1helpful
My ipod wont shuffle anymore
How to Fix an iPod Shuffle That Won't Turn On
Things You'll Need:
* iPod Shuffle iPod USB cable Power adapter
The iPod Shuffle is the smallest member of Apple's line of MP3 players. During the device's lifetime, you may find that the iPod freezes or seems to not turn on anymore. Since the iPod Shuffle does not have a display attached to it, you cannot be notified of any device errors. However, there are several troubleshooting steps you can take to repair your iPod.
Instructions
Plug the iPod USB cable into the iPod Shuffle and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod Shuffle to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod Shuffle memory.
Connect the iPod Shuffle to your Mac or PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Hope it helped.
Have a nice day.
My ipod is not starting
Hi, here are 3 options: 1. Give it a good charge on the computer.
2. Erase all your songs on it so it has a chance to recover
3. How do I fix my iPod if it will not turn on, turn off, or wake up?
"Your iPod Won't Turn On" from the Apple Support Site provides in-depth instructions for troubleshooting an iPod that won't turn on. Apple recommends that you:
1. Make sure the Hold switch is off
2. Make sure the battery is charged
3. Reset iPod
4. Let iPod's battery drain
5. Update iPod's software
6. Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
7. Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
8. Try connecting iPod to the built-in port of a different computer to see if that works.
"iPod Stops Responding or Won't Wake From Sleep" from the Apple Support Site notes that you need to "charge your iPod, then reset your iPod" if it won't turn off or wake up.
For solutions to other specific problems, please refer to the iPod Troubleshooting & Repair Q&A and try the iPod Help links provided for each iPod model on EveryiPod.com.
If after going through all of the above, the issue appears to be a hardware problem, site sponsor Mission Repair offers free hardware diagnosis and an affordable 24 hour repair service by mail for all iPod models.
Have a nice day and Goodl uck to you.
2answers
My ipod wont turn on
If your ipod won't turn on then try these.make sure you click on the blue links for more info.
  1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
  2. To turn the hold switch off, slide it until you no longer see the orange patch.
  3. Press any button to turn on iPod.
ts1383_2.jpg To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
Reset iPod If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
  1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
  2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Ipod
Your iPod Won't Turn On" from the Apple Support Site provides in-depth instructions for troubleshooting an iPod that won't turn on. Apple recommends that you: 1. Make sure the Hold switch is off
3. Reset iPod
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
