Question about Bosch Axxis WFL 2060 Front Load Washer
WFL 2060 - Works ok then stops until i unplug it
I have a WFL2060. The washer works and then stops with 2 lights flashing. If i unplug it then it usually starts to work again. Sometimes i have to unplug it several times.
Now i cannot get it to work for more than about 1-2 minutes sometimes less without it stopping.
Is this probably a board and if so are they repetitively easy to replace as read a post where someone did not know how to set the switches on the board? Could it be something else like it stops if it cannot get water...
any help would be appreciated.
  • john884 Dec 30, 2008
    Thanks for the reply. That is two separate parts i presume. how can i troubleshoot this problem down to one part?
  • 54 Answers
The following manual has some simple troubleshooting in it starting on page24 this may or may not help
if you could include some further information
it sounds most likely that the water is unable to fill correctly "kinked or plugged" however if this does not fix it put your washer into spin and allow it to run does it complete a spin program ?
if you can get it to complete a spin then the problem you have is a water level/pressure switch
Posted on Dec 30, 2008
    Master:
  • 416 Answers
It might be cold water supply, check the hoses coming to it
If there is not enough water unit simply can not switch the cycle.
Timer also can be a problem, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to check/replace the timer.
Good Luck
    Top Expert:
  • Bosch Master
  • 69,199 Answers
Most likely this is the electronic timer and or the control board, changing it should be a straight forward plug in.
Wfl2060 replace belt
Remove the back panel, slacken the motor and place the belt in line then tighten the belt with the motor adjustment.
Jul 08, 2014 | Bosch Axxis WFL 2060 Front Load Washer
My whirpool washer does not spin in rinse cycle
pull out the plug first ???
have you cleaned the filter ,this is the first thing to do
next check the motor brushes
May 27, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Pump clogged
Hi, welcome to fixya.
If your washer is indeed a WFL2060, this is how to reach the filter and clean it.
**Unplug the washer from the dryer or wall, or turn off the 30amp breaker at the home service panel...safety first**
1) Open the small square plastic door at the right bottom of the washer.
2) Via the small hose drain any access water from the pump...this is where a wet/dry shop-vac comes in handy, or a shallow pan with a few towels works as well.
3) Then turn the pump insert/button trap counter clock-wise and pull out. Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting "fixya", please take a moment to rate the info provided for you here.
Good luck.
macmarkus :)
Jun 27, 2010 | Bosch Axxis WFL 2060 Front Load Washer
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL2060 stopped working on a wash cycle. The first time I used liquid HE detergent. I am sure I put too much in and the interior foamed up, the detergent tray foamed up and came out underneath...
water in base after overfoaming has leak detection if you can tip machine back this water will run onto floor allowing unit to rest, make sure you put down some rags towel etc to trap water there will be up to a pint of water.
Jan 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
27 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
