Question about Nokia 6070 Cellular Phone
Detection problem When I connect myNokia6070 by using Dku-5 cable the computer doesn't detects it. What can i do?
    Problem Solver:
  • 18 Answers
Get a dku2 cable or conect using ur phone's bluetooth with using the pc suit.. thanks
Posted on Dec 31, 2008
MY WD MY NOTEBOOK IS NOT DETECTING DO WE NEED SOFTWARE TO INSTALL FOR DETECTION
It does have software for it, but it doesn't require it. Try to connect it to another computer, and if it works there, see if that computer has any detection software. When you connect something to an usb port if it says "this device could work faster" do not hesitate to click that button. Try all of your usb ports. If you use a mac try connecting it to a pc.
Jun 13, 2011 | Western Digital My Book Essential 1TB...
I need a unlock code for my n70 can you help me its urgent i have alot of phone numbers that i can't reach i have a nokia b70 ande can't get into it
If security code, use 12345 If network lock, follow the following steps.
You should have
- - DKU-5 USB cable with its drivers properly installed
- - BB5 unlocker by Dejan( you may google its all over the internet free)
- - And your phone
Unlock steps
1. - Connect DKU-5 usb cable to computer
2. - Check from >my computer properties > device manager> com ports to make sure that your DKU-5 “USB to Serial” com port in in range 1-9 if not, you can allocate it to that range.
3. - Open the downloaded “BB5 unlocker”, locate the file “bb5_unlocker.cfg” open it with note pad and edit the com port number to the one you chose in 2 above. Save and close.
4. - Still in BB5 unlocker folder, find “install.bat” and run it.
5. - At this stage, it should open the real unlocker tool and we are ready to unlock the phone.
6. - Connect your powered on BB5 phone( N70 in your case)
7. - Click READ PHONE
8. - Click MAKE LOG, log will be created
9. - Now run BB5 calc, it should say ok
10. - Now open c:\bb5_unlocker\BB%logunlocker
11. - Click UNLOCK SP, it should say “successfully unlocked”
12. - That’s it you are done and phone is successfully unlocked.!!!!!
Regards
Jan 02, 2010 | Nokia N70 Cellular Phone
I get an usb device. i can't find driver.
The Nokia DKU-5 cable is a serial cable with all the brass connectors and is usually blue in colour at the end.
That cable usually needs a driver for it and acts at the modem cable in most cases.
Right click on computer and select manage, then select device manger. Click on the + icon next to Com Ports and Modems, there you will see when a device or special cable is plugged in.
Here is the DKU-5 driver>>>>>>>>>>>>>>
http://europe.nokia.com/appmanager/UnitedStatesEnglishEUROPE_NOKIA_COM_3/Get_support;JSESSIONID_NCOM=d6zzKLqL1BPhbGVcQTDjyF9YKtLvXvZhLJKsvf5hCsMSLmVDRdjg!-1431951435?_nfpb=true&_windowLabel=T2041828831149690107959&_pageLabel=P163319&wsrp-urlType=blockingAction&wsrp-url=&wsrp-requiresRewrite=&wsrp-navigationalState=&wsrp-interactionState=_action%3D%2Fpageflows%2FEMEASupportTool%2Fbegin&wsrp-mode=&wsrp-windowState=
Good luck.
Aug 18, 2009 | Mouse Systems Mouse (The Mouse model) by...
Detection problem of video cam panasonic gs90 ev
Hi
If you're using windows XP, the camera will be automatically identified.
Anyhow, try the following:
1. Check the cable for any possible defects.
2. Switch off the computer.
3. Connect the cable to both the camcorder and the firewire card.
4. Switch on the computer.
5. Switch on the camcorder.
If the cable and the firewire card are both okay then it is possible
that the camcorder firewire interface is damaged.
good luck
Apr 27, 2009 | Panasonic Palmcorder PV-GS14 Mini DV...
My computer not detect my phone nokia 6070 i have a cable dku 5 n i have nokia pc suite 6 plese tell how to conact my phone through this cable?
fist of all check your data cable for ok .and connect your phone in any another usb port. if problem not fix .
then check any another nokia phone for detecting ,if your computer detected any another phone then reinstall your pc suite or update with any new version
Apr 24, 2009 | Computers & Internet
Nokia pc suite do not recognise dku50 data cable
after you have installed nokia pc suite in your computer plug the data cable and restart your computer. it should automatically detect. if not switch off and on your phone along with the cable connected. if still not detected the you have bought the wrong data cable
Dec 19, 2008 | Nokia 6220 Cellular Phone
Dku-5 data cable problemm
then it must be a data cable problem ,u should see whether this is a correct cable that u connect if this is nt go for a new one
Oct 16, 2008 | Nokia 6610
Phone and PC connection
Possibly cable is the problem, may be it is DKU-5 cable. You need DKU-2 cable for this phone and latest Nokia PC Suite. It is recommended from Nokia.
May 21, 2008 | Nokia N70 Cellular Phone
Nokia 6070
6070 support ca-42, so what exactly u mean, it doesnt recognise your phone (restart phone once and plug it back to pc), or it doesnt detect modem (you need to manually add nokia 6020 cable modem, there are no 6070 modem drivers for ca-42) ??
Feb 22, 2008 | Nokia 6070 Cellular Phone
N70 connecting to pc problem
Nokia itself approves DKU-2 as th e needed cable for nokia n70 . i think the pc suite you r suing is too ols as it cant detect n 70 . plese doenlaod latest pc suite from nokia website
Dec 03, 2007 | Nokia N70 Cellular Phone
Nokia 6070 Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
