Question about Car Audio & Video
2008 FORD EXPEDITION WITH SIRIUS RADIO. REGULAR RADIO STILL WORKS BUT SIRIUS QUIT WORKING. I THINK IT MIGHT BE A BAD WIRE?
  • Steve lv May 14, 2009
    I have the same problem with 2007 Expedition EL. At Max volume fery faint, very distorted programming can be heard. All the program info displays such as channel name, Program name, etc.
2 Suggested Answers
hfmiles
  • 1165 Answers
SOURCE: Ford Expedition 2007 Sirius radio
Did you check to see if your subscription expired?
Posted on Feb 11, 2011
How do you pull the radio out of a 1998 ford expedition to get to the GEM?
thats easy the dash panel around radio just pops off with flat head screw driver and 4 bolts hold radio in.however the gem is not behind the radio its behind the fuse block in the dash. in addition if your radio is not working it could be a bad fuse or bad wire .does the radio light up?if so then its not a bad fuse or wire .in witch case check your model xlt eddie baur etc some model have just basic radio other have radio with external amp in the dash behind radio these often go bad it is then up for you to decide to get original equipment to work or install aftermarket radio in some cases after market radio is cheaper and depending on the model you purchase perform better .yah unfortunetly car manufactures install cheap radios in all vehicles wage your options aftermarket radio cd player say sony brand usually around 60$ and shud only take 1 hour to intall hope this helps good luck
Oct 18, 2014 | 1998 Ford Expedition
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
My 2008 ford focus sirius radio stopped working. sirius tried to reprogram, but it didn't work
Did Sirius resend a signal? If it is displaying their number it is likely that your subscription needs to be updated. The fact that it displays their info means it is likely receiving a signal. If it said "no tuner" or nothing at all, it would likely be the tuner. You can resend a signal online here:
http://www.siriusxm.com/activationhelp
If that does not work, replacement kits are available here:
http://www.tss-radio.com/products/isimple-factory-ipod-and-sirius-integration-for-ford-lincoln-mercury-vehicles-1
Jun 24, 2012 | 2008 Ford Focus SE Sedan
My 2008 Ford Edge cannot seem to hold the Sirius signal. It works intermittently. For no known reason I lose the signal. (No Signal) I have called Sirius and they have sent an activation signal and it...
I had a similar problem. Tune your sirius to 184, leaving the radio and the key on with the drivers door open. Let set for 15 minutes. Before you do this procedure, call sirius to tell them to send a boost to your radio. This should take care of your problem. Good luck :)
Nov 18, 2010 | Ford Edge Cars & Trucks
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
Nov 12, 2009 | 2009 Ford Escape Hybrid
I have a 2006 expedition with satellite radio capability. however when you push the sat button on front of radio it displays "no sat" any advice
have you subscribed to the satellite srvice that your radio has ? sirius or xm radio? the only way to get these channels is to pay a monthly subscription
Sep 25, 2009 | 2006 Ford Expedition
Sirius radio reset on dodge ram 2008
I have the same problem. When Sirius sent me a new "update" signal, I lost more channels. They don't have any idea. Did you figure out how to reset?
Oct 25, 2008 | Sirius Satellite Radio Sirius Starbase...
RADIO,
Have you checked the ground?
Aug 25, 2008 | 1995 Ford F150 Styleside Regular Cab
Car Audio & Video Logo
159 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
