Question about Miele Dishwashers
Miele Igonito Dishwasher red light for Intake/Drain flashes
Dishwasher stops. Checked inside with my hand to find objects that may clog a drain but seems to be clear (inside dishwasher drain net).
  • mac_m Jan 02, 2009
    Sounds like good advice. Tried the power off step but the problem continues. Will call service firm to inpsect further. The last firm recommended a $850 repair, so I will seek a second opinion as I did not trust the person's expertise and question his profit motive.
  • Miele Master
  • 19,396 Answers
Try unplugging power cord, or tripping circuit breaker to cut power for ten minutes or so.
If the problem persista on startup, better calling a technician.
Posted on Jan 02, 2009
  • Ginko
    Ginko Jan 02, 2009
    Try first unplugging power cord, or tripping circuit breaker to cut power for ten minutes or so. This will drain power from the unit and can reset the error code.
    Check also that water is coming from the supply. Ensure that the door is closing well, and sensor is not stuck.
    If the problem persists on startup, better calling a technician, parts like inlet valve, pump, control assembly, and motor assembly must be tested and eventually replaced.
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
I have a misled g843scvi dishwasher. The intake/ drain light is flashing, machine start then fails. Any ideas
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please revert back for further assistance.
Thanks
Rylee
Dec 23, 2011 | Miele Dishwashers
Drain is clogged
I had a flashing red Intake/Drain light. After calling Miele tech support, he confirmed that the drain was plugged so I took all drain hoses apart and finally discovered that the problem was a plugged air gap. I replaced it and the problem was solved.
Nov 18, 2009 | Miele Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele novotronic disher
Hi
When the dishwasher stops.....is there water in it?
Sam
Melbourne Domestic Appliances
0424395512
Apr 08, 2017 | Miele 24 in. Novotronic G851 Plus Built-in...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
160 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
