Question about HP LaserJet P2015dn Printer
What do the sumbols on my hp printer mean
The are 2 lights flashing in my hp printer.. wat do dose symbols mean?
  • Muggs01
    Muggs01 May 11, 2010
    what 2 lights are flashing
    Novelist:
  • 102 Answers
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Posted on Jul 03, 2009
5 Suggested Answers
  • 1019 Answers
SOURCE: red light flashing, And little cartridge symbol on printer screen,
Check the ink levels, and that there is not a paper jam.
if nothing of those two, try uninstalling and re-installing printer drivers. sometimes you can unplug the printer for 20-30 minutes. which may enable it to reset to it,s default settings. if this does,nt help. refer to the user manual.
good luck Mike @ Compurepair.
Posted on Feb 20, 2008
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Posted on Feb 14, 2009
Joed911
  • 4338 Answers
SOURCE: e3 flashing wat does it mean
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button
3 times for Orange EEPROM reset.
Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
3 times Orange EEPROM reset
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
iron_luiggi
  • 91 Answers
SOURCE: My printer won't print. (HP P2015dn)
If the triangle is on and the powe light is on too, is a Manual Feed or Continuable Error
This state can be reached in the following circumstances:
Manual feed,
General continuable error
  • Memory configuration error
  • Personality/Job related errorSOLUTION: To recover from the error and print whatever data is possible, press theGo button.If the recovery is successful, the printer goes to the Processing Data state and completes the job.If the recovery is unsuccessful, the printer returns to the Continuable Error state
    another reason is that the cartridge cap may be open or not closed, remove the cartridge and put it again, should work
    If you've put a dimm memory (memory expandable to one side of the printer, remove it and try one more time
    if you did not work, it may be a fan failure the printer, or the engine, or the DC controller, if that is your problem is preferable to contact an authorized hp.
    I have the same machine, it is good quality, and does not give many problems. regards
Posted on Apr 05, 2010
What does the ! in the traingle symbol on printer p2015dn mean as printer not working and this symbol is flashing
If just that light is flashing then it most likely means that the print cartridge door is open
Sep 30, 2009 | HP LaserJet P2015dn Printer
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
Orange light is flashing
Unplug the power cord for 10 seconds
Feb 05, 2009 | HP LaserJet 1020 Printer
Red light flashing, And little cartridge symbol on printer screen,
regrads
ISKANDAR
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
1 red light
1 red light means general hardware failureand it is pretty much the same as 3 red lights but it is has a slightly different problem. if you are under warranty send it of to microsoft. they will repair it for free. if not buy a new warranty for 60 dollars.
Nov 29, 2008 | Microsoft Xbox 360 Console
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
2 red lights after x clamp replacement
It means basically that the xbox is starting tio overheat fast. what sometimes happens is those x-clamps have to be tightened in a sequence and tight as possible but not too tight to crack the board or cut the small PCB traces. Open up the console again and just have a look underneeh the motherboard make sure there are no torn green pcb traces ( put simply green lines that connect to a silver blob of solder ) and make sure the screws are tight enough.
Dec 11, 2007 | Microsoft Xbox 360 Console
HP LaserJet P2015dn Printer Logo
434 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
