Question about Philips Magnavox 15MF400T 15 in. LCD Television
37 inch Magnavox flat panel LCD approx 2yrs old won't show pictur
37 inch Magnavox LCD will not come on after being off for more than 5 minutes. The green light comes on and starts flashing, but no picure. It started taking 5 minutes to come on and progressed from there. I think its totally out now, because the light flashed green all night and never came on. Occasionlly it will flash a white screen, but only for a second or two after it is first turned on. I seems this is a problem with many magnavox tv's, but I haven't seen a solution listed yet. If anyone has had one of these repaired, what was the cost? Cheaper to buy a new one? If fixed one on your own, how difficult?
  • 3 Answers
SOURCE: 50mf231d/37 magnavox plasma
i have the same problem but i play with it by pluging it in multiple times and i hear it click on then off eventually the time between it clicks on then off is longer until i finally get it to stay on .I have to do that everytime i use it . Also the update wont work for me either tried everything. It must be with the power supply becuse once i get it on it stays on, and if i turn it off after its been working for a while it comes right back on perfectly. Only when i leave it off for a few minutes the symptoms start right over.This is what i do for about 5 minutes of plugging it in and out it flicks on and then off about 2 seconds later after that ii finally get it to flck on then off about 6 seconds later. 5 more minutes of pluging it in and out it takes about 10 seconds to flick off this is when i know it is about to work.finnally the green light will stay on and the tv wont flick off you can turn it on and of with the button wait 2 min to see if the picturecomes on repeat last step until it works.This means everything works great exept for the power supply for enitial startup. I beleive its a capacitor . I will check and report back.
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
  • 563 Answers
SOURCE: magnavox 42mf230a/37 turns on but no picture or
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're under warranty or you purchased an extended warranty or service plan, the repair costs will be covered.
If you're not in warranty you'll have to pay for the repair. The cost would likely be a minimum of $300+ for parts and labor. The circuit boards in these new LCDs are not cheap at all! I've seen repair costs averaging $450 and up for large LCD TVs.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Posted on Sep 26, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ... > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Televison & Video
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like, to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Screen goes dark after a few minutes of tv on
It has bad lcd inverter and Westinghouse don't sell the parts either.
Mar 23, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
May 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Junk from magnavox.
Trying unppluging wait one minute and plug in again.
Aug 31, 2008 | Philips Magnavox 42MF521D/37 Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips Magnavox 15MF400T 15 in. LCD Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
