Question about Goodman Heating & Cooling
Blower squeak! Bearings or Bushings? Can it be greased?
Blower on air handler just started squeaking. Without pulling it I don't know wheather or not it can be greased. So, do I have one ready to go back in and if so where can I get a motor for it, or can it be greased? It is winter so I don't want to mess with this thing long. Thanks! D. Hobbs, Ky
  • 242 Answers
Most elec. fan motors can not be oiled , try holding the blower assembly with the fan running to see if that stops the noise , if it does not you need to replace the evap. fan motor and if the blower wheel is dirty clean it , if there is alot of rust on it replace it as well. Good luck.
Posted on Dec 30, 2008
How do I grease my nitro since it is squeaking?
Usually suspension parts are not serviceable and need replaced such as ball joints, tie rods, bushings even wheel bearings.
Jan 15, 2016 | 2008 Dodge Nitro
2001 Buick LeSabre Ltd. 128,000 miles. All new front struts and rear air shocks and stabilizer links. Even before that I get a creak (sounds like rubber) from both front sides when I go 15 mph over sp
Sounds like it could possibly be the upper or lower control arm bushings squeaking. There may possibly be a grease fitting on the control arm bushings, if so, have them greased. In fact get a complete grease job from a qualified mechanic. If the squeak stops then you know what is wrong. Then make sure you keep your care properly greased. Usually every time you change your oil or at least twice yearly.
Oct 29, 2014 | 2001 Buick LeSabre Limited
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
Air Handler squeals when starting and stopping
If this unit is belt driven, the belt may be worn or slightly loose.
Jan 20, 2014 | Rheem RHSL-HM1817JA Multi-Position Air...
My front in squeeks an creeks when i hit a low spot or bump. I have had in the shop 3 times> I bought an extended warranty. I am bought ready to give up.
Front end squeaks are usually caused by rubber suspension parts. The most common source are the sway bar bushings. Nest would be the control arm bushings. You can spray the bushings with penetrating oil to see if the squeak stops. This would only be a temporary fix. Do the sway bar bushings first. Spray them down really good, and drive the car for a couple of days. If the squeak goes away, you will know you need to replace the bushings. Do the same thing to the control arm bushings. If you replace any of the bushings, use a high performance neoprene bushing, and use the special lube available before installation. The sway bar bushings will be an easy fix. The control arm bushings will require special equipment, and will need to be done in a shop.
Feb 18, 2011 | 2008 Mercury Milan
My 2006 Chrysler Sebring touring suspension recently started squeaking after my winter tires were installed.what could be the cause of this?
the tire might be rubbing on the strut assembly but i betting its just cold grease when it gets cold the grease gets thick and the rubber bushings in the suspension get stiff making squeaking noises i would take it to a oil changing place and have them grease the chassis that should help.
Dec 24, 2010 | Chrysler Sebring Cars & Trucks
How to stop squeaking noise on dryer
The roller bushings/bearings and the motor need lubricating.
If you want help with how to do this, let me know.
Apr 30, 2009 | Dryers
2000 Chrysler Sebring Conv. replaced struts-front end squeaks on brake and turn
the reason why ur car squeaks is the ball joint i have a chrysler and same thing happened n my friend knows a lil bit bout cars had the same prob with hiss car and then the tire came of came to find out it was the ball joint causing the squeaks its not bearings or ur brakes car places told me same thing didnt fix it it is 100 percent ur ball joint and when u ask for the part ask for a lower control arm with a ball joint and install it by whoever
Nov 06, 2008 | 2000 Chrysler Sebring
Squeak and rubbing on lt side drivers side tire can move and squeaks
I'd lean toward bushings of some sort. Inspect the control arm bushings for signs of cracking, and check the sway bar endlink bushings for wear and tear. Both of these parts are going to be worked harder on uneven roads than they will on a smooth freeway, and are likely candidates for causing your problems. A third possibility would be worn strut mounts, but I'd look at the control arm and swaybar bushings first.
Jul 21, 2008 | 1999 Mitsubishi Eclipse
Consistent Squeaking Noise
The fuser unit, [near the paper exit] which heat-sets [fuses] the toner onto the paper, has bearings (bushings) that are screaming for high-temperature grease. Open it, and apply some common sewing machine oil onto the bushings. If the noise stops, you will need to repeat this every 2-3 months or disassemble the fuser roller and apply high-temperature grease.
Jun 23, 2007 | Sharp AM-900 All-In-One Laser Printer
Heating & Cooling Logo
527 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
