When try to change date/day when put crown in first position, it will not allow me to advance it manually when I turn clockwise or counterclockwise - like it is stuck. The date/day changes with time, But I cannot change manually. I hope you can help. I purchased 10/05/2012, and it was working when I first got the watch. It is not now. I set it by instructions, and the date/day did not advance correctly. So, I ended op having to changing by turning time several times to get date/day correct - could not do in 1st position - had to do in 2nd position. Will I be able to do date/day in 1st position manually again (what caused this). Please help. thank you
SOURCE: Need instructions for setting a citizen eco-drive watch
try this link:
http://www.citizenwatch.com/COA/English/settings.asp
Rate, please.
SOURCE: Citizen eco-drive BM8084-58H: I cannot change the
mcdevito75 here, The crown should be a 2 position crown, try this, pull out the crown as if to set the hands, rotate the hands, (adjust the time) around the dial until you have the right day, Now! push the crown in, Now! slip your finger nail just under the crown and lift the crown to it"s first notch or position, this should allow you to turn the crown and adjust the date, when at the date push the crown back in and your done.
SOURCE: I was trying to set
Hi, I don't believe you have actually got it back on(the crown) properly. You will have to take it to a watchmaker to be done correctly. I think your setting problems will go away once the crown is attached to the stem correctly, Michael
