Question about Pioneer PD-M423 CD Player
Pioneer PD-M423 CD player will no longer read CD's. For each CD, I hear either a high-pitched buzz for a few seconds, or 3 clicks, then it moves on to try the next CD. Unit was recently moved several hundred miles by truck. I already checked the laser lens per Robotek's solution, it's still in place. There are no loose parts inside the unit. Any suggestions?
Ribbon cable track(s) from pcb to laser assembly brocken
First - check all tracks for continuety, before suspecting motor or laser assembly.
Posted on Jan 14, 2009
Have the same problem. Had friend, electronic tech look at it. Pickup assembly failure. Use Partstore.com or Pioneer to find part and then cross reference with other models that use same part. I bought used item on Ebay, $40 to repair my unit. Simple 5 screws, two pug in cables. Be sure to discharge static electricity from body before touching interior parts. Up and running in 20 min,
Posted on Jan 01, 2009
Pioneer model # PD-M423 won't read the CD and ejects it.
If it is with all clean cd's then it can be a dirty lens which you can buy cleaner for, but i've read the manual and was dated 1993, so if a cleaner not helps , it's the unit itself and time for a new player. Parts are very expensive and it's one whole unit..... I think it's the end.
Greetings richard
Jun 06, 2014 | Denon DN-S3500
I lost my remote control for my PD-M423. Where can I obtain another. thanks
Search Engines find these things faster than awating Expert response.
One place...
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=PD-M423&uuid=A13123011804801
There are several cheaper ones on eBay.
CUPD068
Aug 02, 2011 | Pioneer PD-M423 CD Player
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
CD player does not play discs
Laser has died ,problem with pioneer is laser costs are ridiculous and write the machine off
Jan 01, 2009 | Audio Players & Recorders
Do we have to have the PD-M423 CD magazine for our player
I have 14 magazines (CD holders) that I want to sell. I also have a unit and the remote to sell too.
Jan 01, 2009 | Pioneer PD-M423 CD Player
Pioneer PD-M423 CD Player Logo
446 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
