Question about ViewSonic N3735W 37 in. LCD TV
I cannot get my cable to show in full screen. I have Time Warner HD service. Im hooked up right, but my picture does not use the whole 37" screen. When I change my picture width, I get No Scale, Full, Normal, and Zoom. The first three are exactly the same, Zoom will zoom the picture in full screen, but it cuts off part of the bottom and top of the picture. How do I fit my picture to full screen without cutting part of the picture out?
  • aj_ross88 Dec 30, 2008
    My friend has a 57" HDTV and his service is full screen, so It is possible.
    Well, Im on a 37" Viewsonic LCD HDTV with HD service. Why cant I get the picture full screen? The tv setting will not adjust my screen.
  • ViewSonic Master
  • 5,568 Answers
For HD you have to have a square screen
Sorry to disagree; the standard screen has an aspect ratio of 4:3, this is far more 'square' than the 16:9 (aka 'wide screen') which is standard for HDTV. If you are on cable or satellite service, you may well have to pay extra to have the whole of your screen available for viewing.
That is why only 'over the air' broadcasts are absolutely affected by the change from analog to digital next February but other sources do not have to change over to the new standard and the 4:3 sets will work fine without any extra box until those sources decide to 'go digital.'
Posted on Dec 30, 2008
You can't. I have the same problem but it is impossible. For HD you have to have a square screen, so the picture only uses the biggest square it can get. For regular cable, it is streamed at a ratio, so tough luck.
Picture showing up small
hi try going into the menu on the tv select aspect raito select auto or 16.9 hope it helps
regards
shaun
Apr 04, 2014 | Panasonic 37" VIERA Full HD 1080p IPS LED...
Tiny "guide-size" screen remains when I'm out of guide
HI,
I'll let you know if there is a mnual available online for your model.So that you can find out some troubleshooting steps.
Apr 16, 2008 | Philips 42PFL5332D 42 in. LCD Television
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Not getting full pic on certain channels
I've seen this problem before. Try to adjust the horizontal settings in the tv. you should be able to adjust the picture up just a bit and it will get rid of the lines. also if you are hooked up thru component or hdmi you should be able to press the # button on your time warner remote to fill the screen. Hope this helps.
Feb 10, 2009 | Philips Magnavox 42MF521D/37 Television
Someone was messing around with our settings yesterday and now the picture is not full screen. How can we get the picture to fill the screen?
i was going crazy then i finally found a clue on google: hit the setting button on your digital cable remote, go into 'display', change aspect ratio to 16:9, screen size to 'stretch', and output to 1080 or 720 depending on what you have. Were HD channels full screen? If they were they were NOT set properly as above anyway and non-hd channels were black on both side with some having black all the way around on some channels, correct? Hope it helps! I have time warner digital cable and an 52 LG 70 with HDMI...no settings on your tv will fix this if you are in a similar situation b/c its the settting in the digital cable box that need to be re-adjusted.
Nov 28, 2008 | Televison & Video
Depending on the manufacturer of the cable box, there will be a menu somewhere regarding aspect ratio using the terms - cropped, zoom, and a few other terms as well. You probably want cropped, which will cut some of the sides off, but you wouldn't miss the picture as a whole when view at full screen. Hope this helps!
Jun 14, 2008 | Toshiba 43H70 43" Rear Projection...
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
ViewSonic N3735W 37 in. LCD TV Logo
533 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
