Question about TallyGenicom 2280 Matrix Printer
I need to know proper placement for printer ribbon tally 2265 / 2280
    Novelist:
  • 169 Answers
The Reference Manual for the 2265 on the Dascom web site should show you how to repalce the ribbon;
http://www.dascom.co.uk/documentation/serial-matrix/61-t2265.html#176
Posted on Dec 15, 2009
What is the cause of error +0001 +131 Hardware Alarm, Check Ribbon 000002+5085+3010 on a Tally Genicom 7265 serial printer. Any help would be great
The Printhead is not where the printer expects it to be. Usually the carriage is jammed, which can be caused by a faulty ribbon. If the carriage is not moving freely with the printer off try to find what is causing the bind.
Mar 01, 2016 | Tally Office Equipment & Supplies
Showing Ribbon Fault
hi
clean the ribbon then if still same error chang the ribbon
Jun 19, 2011 | Tally 6312 Matrix Printer
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Apr 21, 2010 | Tally T6218 Matrix Printer
I am getting a constant Ribbon stall on one of our p5010, we have totally cleaned hammer bank areas and put in new gold ribbons, we compare ribbon drag on the stalled p5010 to our many working p5010 and...
there are few things.. may be your ribbon hub damage... your ribbon motor not working properly.. check ribbon motor connection...and finaly L/C..CMX..CFX board.
Mar 10, 2010 | Tally Compaq Line Printer LG05 500 LPM...
Tally 6218 hammer voltage 2
Hammer Voltage 2 is the worst error you can get on the Tally T6200 series...
Explanation:
A high resistance coil fault has likely occurred in one or more of the
hammer coils.
Note: This fault message will have been preceded by printing slow-down
attempts associated with On-The-Fly thermal monitoring of hammer
bank temperature. Check blower underneath ribbon Deck.
Corrective Action:
Check the hammer bank for defective hammer coils qty 7 per hammerbank.
Confirm that hammer drive board is functioning properly.
Aug 25, 2009 | Tally T6218 Matrix Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
TallyGenicom 2280 Matrix Printer Logo
253 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
Kolbrun...
Thomas Charalabizas...
Level 1 Expert
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
