Question about Toshiba Satellite A75-S229 Notebook
When I turn on my toshiba satellite laptop it displays the toshiba screen as it normally would, followed by screen with black and white progress bar at bottom but freezes at about 1/4 the way. So my only option is to restart. Then I tried doing the F8 thing to get to the startup screens with all the configuration settings. I can't get any farther than this. I tried using an xp boot disc I downloaded off the internet and this also gets me nowhere? Any suggestions?
    Scholar:
  • 34 Answers
White 1 in. Bar running from top to bottom of screen
Plug in external monitor to see how that works. If it does same the issue is with your laptop. If it works fine the issue is with your laptop display that needs replacement.
Aug 31, 2017 | Toshiba Satellite M65-S909 (PSM60U02W021)...
Windows failed to start
You need to re-install windows mate.
May 20, 2010 | Toshiba Satellite A305-S6852 Notebook
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
Power on No Display(Black Screen)
try pressing FN and F6 together when u turn it on
Mar 11, 2010 | Toshiba Satellite A135-S2276 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Windows Won't Load
Same thing happened to me. Looks like your windows install is damaged. My advice, do a fresh install of windows. You won't lose any of your files, but you will have to reinstall most of your software and drivers.
Jul 01, 2009 | Toshiba Satellite L355D-S7815 Notebook
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
