Question about Toshiba Satellite L25-S119 Notebook
3 minite and above take for laptop booting © problem
Configuration-H.D 250GB RAM-1GB when i power on my computer take above 3 minites to boot.
also it take above 20minite to copy within inbuild memory and external device.
  • 741 Answers
Here are some things you can do that will boost your performance back to normal.
First, go into Start>All programs>system tools and run Disk Cleanup. This will get rid of all of the junk like *.tmp files that has built up. Second, in the same place after you run DiskCleanup run Defrag. This will take care of all the gaps on your hard drive so data can be found more easily. Finally you need some more RAM. 1GB these days with all the intensive programs is minimal especially if you have a 250GB HDD. Means if you load that puppy up your access time will be very slow with only 1GB. All programs load into RAM when they run, so with only 1GB your system has to constantly keep going back and forth to your hard drive to get code and that makes it very slow. Hope this helps and thanks for using FixYa. If you have any problems let me know.
Posted on Dec 30, 2008
How to reinstall windows 7 and all drivers
Get your Win7 DVD, place it in the DVD drive. Configure the boot order to boot from DVD drive first and boot from the DVD. After installation, download and install all of the drivers for your model from the manufacturers web site.
Dec 29, 2013 | Hannspree HannsBook SN10E2 Atom N470...
Windows will not start on my laptop
2 choices turn the comp over un plug the battery leave about 2 minits.
then plug back in and try again .
If that doesn't work then when it starts 2 boot up press F8 several times it will ask normal start or select last known good configuration & select it . if that doesn't work have u aback up disk insert the 4 th disk and boot from that insert tha disck turn off comp and re start it will come up boot from disc press any key yes thats shold b it
Oct 02, 2012 | Sony VAIO Computers & Internet
After instal windows7 the system hangs after several minits
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
make sure your ram modules are seated properly with no dust in there sockets
click start right click on computer select proprties you will see ammount of ram installed and usable ram
also cmos battery is seurely seated with no dust in the socket on some motherboards cmos
batteries are soldered in
computers need power and data to travel through every working deviceand to have a finishing point to work
scroll to bottom toolbar (bottom of screen) right click select task manager applications see
whats running also applications if you see something running that should not click end now
hope this helps you
Sep 26, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Hi guys i am facing problem while trying to install or even boot from CD or USB, my problem it's when i press any key to boot from CD i just get blank screen and i thing the laptop is stuck. Please...
Ok so I'm guessing it's detecting it's a bootable CD since it is prompting you to "press any key to boot from CD" right? If it goes to a blank screen after that and doesn't go any further, I would think it's 1 of 3 things.
1, the CD you are using is bad or damaged. Try a different bootable CD or try to burn a copy of that one and try with the new copy.
2, Could be a memory issue. If you have multiple sticks of RAM in your computer, try removing 1, testing, then the other (while replacing the first one you removed).
3, Your Hard drive could be corrupt or damaged. I would first try wiping it clean with a program like Darik's boot and nuke (http://www.dban.org/). THIS WILL DESTROY ALL DATA ON THE HARD DRIVE. Then try to re-install again.
Jun 24, 2011 | Computers & Internet
Tried to power up my eee PC but only grey screen with logo comes. All keys freeze. Tried with and without battery, Tried plugged with power cord and without. Nothing worked.
Please remove the RAM, Hard disk and battery. press the power on button for 1 -2 minites. then insert only one RAM on another slot. Start laptop with AC power. Whether is it displaying the NO BOOT DEVICE or not. If display no boot device, please insert the Hard disk. then try..
Hope this helps to you.
If your problem not solved, please let me know...
Jun 18, 2011 | ASUS Eee PC 1001P Netbook
Whe i make power button on, he press f1 to BIOS setup utility and press f12 for temporary boot device. when i hit f1 or f12 after some minit, he display just like lock icon on screen and some times says...
Check the laptop is booting by connecting it to an external monitor and see if the lock appears there you may need to press Fn and F7 keys to switch display
If it does not, then try pressing Fn and scroll lock
Jan 10, 2011 | Computers & Internet
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Oct 02, 2010 | HP Mini 110-1037NR Netbook
My computer was booting over and over so removed
hi
if you have done the memory removed along with remove your CIMOS bettery from motherboard along with RAM leave for 10 to 15 minits without both memory after that try hope fully it will work
Jul 19, 2010 | HP Computers & Internet
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.
Remove battery and power for a minit, install it again, power up mains and try again. This helpe me here in Paraguay several times.
Saludos Wolfgang
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
How to load the o.s.
First you can take One Bootable O.S CD and
Goto BIOS Boot priority First option CD Rom
Then Boot from CD then Press enter any Key to Continue.........
After that Windows Setup Running it will take several minits then select F8 button and Select partition and create New Partitions select C or D drive press enter Boot files Loading then Reboot your System After that instalation time asking CD key and Time Zone select it after several minits installation will be complete.Thats it
Jul 11, 2009 | Fujitsu Point 510 (FMW2631SA03) PC...
Toshiba Satellite L25-S119 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
