Question about HP DeskJet 5150 InkJet Printer
My printer won't turn on
Was having no problems with last use, no apparent reason for it not to turn on
  • songbird_473 Dec 30, 2008
    Thanks--it worked!
I have had the same problem and I just unplug and plug back in then hit the on button
Posted on Dec 30, 2008
My DA550 stopped printing for no apparent reason
Often with printers there is a buildup of debris clogging the paper path. Another thing that happens is the rollers get shiny and don't grab the paper. Shiny rollers can be cleaned with alcohol wipes until they are grippy again.
Nov 15, 2013 | Office Equipment & Supplies
My truck won't start battery is good y won't it
how can anyone help you with out knowing what our working on..
Jan 21, 2013 | Cars & Trucks
Car DVD player won't turn off
You will need to remove the player and send it out for repair, the solid state circuit that turns on the player has a defective diaode most likely in one orf the chips.
Sep 04, 2012 | 2004 Volvo XC90
Any idea why it takes a few turns of the key to start my truck? There is 59000 miles on it and the last 2 mornings the truck did not want to turn over. it eventually did, and would start fine in the work...
You have to be specific about the engine turning over
That is done by the starter circuit
Some people call that cranking
Some people also say it won't crank, when they mean
it does crank, but won't start
Not turn over the engine -----
Old & Weak Battery
Dirty Battery Cables
Worn out Starter Solenoid -- you can buy & replace
without getting the entire starter
A bad Starter
Sep 22, 2011 | 2007 Lincoln Navigator Ultimate 4x4
The car sat up awhile. The battery died. We replaced the battery but the car still won't start. Everything comes on. The starter was tested and it was fine. What is the problem?
THERE ARE MANY POSSIBLE CONDITIONS THAT COULD PREVENT YOURCAR FROM STARTING. 1. NUTERAL SAFETY SWITCH IF THE CAR HAS AN AUTOMATICTRANSMISSION. 2. CLUTCH POSITION SWITCH IF THE CAR HAS A MANUAL TRANSMISSION.3. BRAKE PEDAL SWITCH. MANY NEWER VEHICLES HAVE A SWITCH ON THE BRAKE PEDAL ANDIF THE PEDAL IS NOT DEPRESSED WHILE TRYING TO START THE CAR, THE CAR WON'TSTART. ANOTHER POSSIBLILITY IS THE SECURITY SYSTEM. DOES THE CAR HAVE ASECURITY CHIP IN THE KEY? THESE ARE SOME OF THE MOST COMMON REASONS THAT A CARWON'T START FOR NO APPARENT REASON. HOPE THIS HELPS.
Aug 18, 2011 | 1999 Mitsubishi Montero Sport
My brother MFC-885 Printer says it is offline? for no apparent reason, I used it yesterday and it was fine, last night I switched it off from the switch, but I've been using my computer all day today so it...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000086/faq002586_000.html?reg=us&c=us&lang=en&prod=mfc490cw_all
This is what I did for mine just now. I don't know yet if it solved my problem, but thought I'd share if you wanted to try it too. You may need to go through the brother site to find your own model first, as I don't know if these instructions are universal for all their printers.
Feb 01, 2011 | Computers & Internet
RED status light on for no apparent reason. All cartridges (colours & black virtually new)
There are a lot of reason for the red light to turn on, paper jam, waste toner tank full, cartridge failure, etc. The best way to figure out what the problem is us to use the smart panel software and it will tell you what the printer sees as the problem.
Dec 06, 2010 | Samsung CLP 300 Laser Printer
2004 mercedes c240 alarm sounds for no apparent reason
Hi, You need to replace the alarm siren. It is also a module. It is located in the right front fender well. The reason they go bad is because they are located in a place where they get wet.
Apr 03, 2009 | 2004 Mercedes-Benz C-Class
Resume Button
ok..well..not knowing what caused the first problem, you might need new drivers(which fracture for little apparent reason).
get em here
Mar 13, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Power problem
The Printer unable to turn on could be of two reasons.
(1) Connect the Printer directly to the wall outlet instead of connecting through the power surge protector (If connected through surge protector).
(2) Check whether the Power adapter is getting warmed up after connecting to a particular wall outlet.
(3) Try connecting the printer to any other wall outlet and check for the results.
Hope this information would help you in this regard.
With regards,
Ashesburn.
Feb 14, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet 5150 InkJet Printer Logo
52 people viewed this question
Ben Johnson
