Question about Microsoft Word 2003 for PC
Envelop prints wrong return address
When I type a return address in the appropriate window, the envelop prints an entirely different address. It's not related to the default address since there's nothing entered in the default address. This address is somehow embedded in the system someplace and I can't find it.
Have you checked your inser/auto text to see if the unfamilar return address is coming from there? Or tried saving the return address you want to be inserted as an auto text?
Posted on Dec 30, 2008
How do I print envelopes using Word 2013
  1. On the Tools menu, point to Letters and Mailings, and then click Envelopes and Labels.
  2. Click the Envelopes tab.
  3. In the Delivery address box, enter or edit the mailing address.
  4. In the Return address box, you can accept the default return address or do one of the following:
    • Enter or edit the return address.
    • Omit a return address by selecting the Omit check box.
  5. If you have access to electronic postage, for example if you purchased it from a service on the World Wide Web, you can add it to your envelope.
  1. To select an envelope size, the type of paper feed, and other options, click Options, select the options you want, and then click OK.
  2. In the Envelopes and Labels dialog box, do one of the following:
  • To print the envelope now, insert an envelope in the printer as shown in the Feed box, and then clickPrint.
  • To attach the envelope to the current document for later editing or printing, click Add to Document. The envelope is added to the document in a separate section.
Oct 02, 2013 | Toshiba e-STUDIO 165 All-In-One Laser...
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
How to print a envelop
find ur envelop size.
setup ur page in word
type the address
print
Aug 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Envelopes print crooked
A decent printer should print a #10 envelope without a problem. If this model won't do so, return it and get another printer. Suggest Epson or Canon -- AVOID HP printers.
Oct 10, 2017 | HP Laserjet CM2320nf All-In-One Color...
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing on a #10 envelope
Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
Jan 17, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Printing return address on custom size envelope
this is done in the word processor application. when you select eh envelops. you are given the choice of return address, barcode, and what type of envelop.
Mar 07, 2008 | Kyocera Mita KM-2050 Printer
Envelop creation
Try typing the full address in a normal Word document, then select the entire address, then choose 'Mailings' tab, then 'Envelopes' on the left, then 'Add to Document.' Be sure to type in your return address before pressing: 'OK.'
Feb 13, 2008 | Microsoft Office Professional 2007 Full...
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Microsoft Word 2003 for PC Logo
339 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
