Question about HP Inkjet 1200dn Printer
HP Business Inkjet 1200 printer always prints the Alignment Page
My HP Business Inkjet 1200 printer always prints the Alignment Page after 1. turning it on, 2. any print job.
It has all new ink cartriges and print heads. I have tried the "hold down power button and press paper-advance three times" procedure to no avail.
How do I stop this ink and paper wasting irritant?
  • blslater Feb 01, 2009
    I have the same problem and I have re-installed the driver. I am using Windows XP.
  • Anonymous Mar 20, 2014
    there is yellow ink leaking on the path of paper and while printing, there is yellow ink always on print out need help to solve the problem .
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Nov 16, 2009 | HP Inkjet 1200dn Printer
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
Mar 22, 2009 | Dell 948 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
Steps
Thanks
Rizwan
Dec 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
How do you align your printer
WTF...wheres the solution. Bunch a ****!
Oct 14, 2007 | Lexmark X2470 All-In-One InkJet Printer
Print product alignment
just scan the alignment page and complete the process it will not promt you do again. bye
Jun 25, 2006 | HP PSC 1210 All-In-One InkJet Printer
HP Inkjet 1200dn Printer Logo
1,802 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
