Question about Sharp AR-5316 Advanced Digital Imager Copier
Flashes L and 1 and no key accepts any commands.
My machine is sharp AR-5316 E
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
That is for scan forward problem .check motor check home sensor clean it or may bi board.MIAN AKHLAQ
Posted on Dec 31, 2008
Advice on how to re-set sharp ar 5316 copier, procedure.
Hallow, its my assumption that you know the command numbers and their sub-codes and error codes when you ask of procedure. Here is the procedure:
  1. Press #, Interrupt, 0, Interrupt , keys in that order.
  2. The copier display must go off, if not repeat and increase pressing speed.
  3. Enter the desired number and press copy key.
  4. If it has sub-code, then enter it and press copy key.
This is the procedure.
Nov 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
Reset counter of sharp ar-5316
How to reset meter reading counter;
a. in the operation panel ,press * ,interrupt, CA, interrupt keys.Display must go off.
b. enter 84 and press copy key. 000,000 will flash in the display
The copier meter reading is now reset to 0.
Mar 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
How i can enter in service mode of sharp AR 5316 copier
On the panel display, press #, interrupt,0, interrupt keys in that order. Display will go off then enter the desired number and press Print. If the command has subcode, enter it and press Print to execute.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
5316 SCANNER DRIVER
the sharp 5316 does not work as a scanner
sorry for that
Feb 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Dec 01, 2008 | Sharp AR-5320 Black and White Copier
Fix mantainance and developer leds
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
To cancel the test command mode, press the [CA] key.
Press 26. Press the green button.
Press 36. Press the green button.
Press 1. Press the grreen button.
That will cancel the drum reset. The machine will ignore the drum reset at 50,000 cycles.
Sep 28, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
