Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
No manual help,i have a esp 3 and no idea were anything goes or even were the paper goes..i need to see the esp 3 printer broken down to show what goes were and how....please help
    Problem Solver:
  • 10 Answers
Download the manual Kodak - here's the URL:
http://www.kodak.com/global/en/service/products/ekn033541.jhtml?pq-path=10623
Posted on Dec 30, 2008
How to open rear to clear jam on allinoe printer paper is jammed and i don,t knpw how to remove it model3250
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
http://www.4all2sell.com/pdf/Brother-MFC-7340-MFC-7345N-Manual.pdf
May 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Need to replace broken paper tray. Does parts manual show how to order.
You can buy them on ebay like the following link. Kodak does not sell the part on its own. Printer is to cheap for that.
http://cgi.ebay.com/Kodak-ESP-3-ESP-5-Paper-Tray-/200578575161
Mar 07, 2011 | Kodak ESP 5 Printer
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
Jan 16, 2011 | Office Equipment & Supplies
I have an ESP-3 All in One which is flashing the red light for a paper jam. I have cleared out both the back & front of the printer & it still shows error. Its also trying to load the paper really...
I had the same problem just this morning. I ended up disconnecting the power a few times, and finally the printer sucked in all the paper that was loaded in the tray, spat them out and then it was fine. Just try unplugging the power cable a few times and turning it back on and see what happens.
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a paper jam in my kodak esp3-cannot remove the paper,how do I do it?
Hello there
All The Best: Pineworks
Feb 24, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says 'Unable to detect paper width'
The paper tray has some "fingers" that detect the paper.
Remove the paper and tap the sensors a few times to make sure they are not stuck.
Use lots of mamper, not just one sheet so that there is enough weight to press down on the sensors.
Perhaps it is Earth's gravity that is malfunctioning today :)
Sep 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 printers are a ROYAL PAIN!!!
If your replacement is the same as you had, then you need to go to control panel and delete the driver. Afterwords when you plug in your new one it will install the proper drivers for the new machine. Even though it's the same type your computer won't use it properly til you re-install.
Aug 11, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jammed in my new kodak esp 3 printer no idea why this happened. i put the paper in the right way...can anyone help
Try to clean the rubbers that pull the paper from the tray.
Use quality paper, and pay attention to the place where you store it. Keep it in a dry place.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
