Question about Panasonic MC-V7355 Upright Vacuum
No suction in vacuum on a Panasonic MC-V7355
The belt on my vacuum broke and i replaced it. when i turned it on i heard a weird noise coming from behind the vacuum as if the suction was going in through this little device that pops in and out with the suction. I took off the bag to see what it was and it has a little spring that causes it to pop in and out. I hadn't heard this sound before the belt busted. I noticed that the vacuum is not sucking anything up. Another thing I noticed is that the dirt sensor light is not detecting the dirt.
  • 1,462 Answers
Re: no suction in vacuum on a Panasonic MC-V7355
The device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
Posted on May 03, 2007
0 characters
3 Points
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Dec 12, 2009 | Panasonic MC-V7380 Vacuum
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Nov 29, 2009 | Panasonic Vacuums
My Kirby Generation 3 has no suction at all
check for a clog by removing the bag mini emptor (plastic bottom of the bag) twist it off by rotating it away from the vacuum
Oct 04, 2009 | Panasonic MC-V7355 Upright Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Panasonic vacume#MCV573500
it is probably a thermal issue. contact any local vacuum dealer.
Aug 15, 2008 | Panasonic MC-V7355 Upright Vacuum
I own a Panasonic ME-C4051.
Check by the brush roll, the inlet may be clogged, also may be time to change the belt, they stretch after a while.
Mar 26, 2008 | Vacuums
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Panasonic MC-V7355 Upright Vacuum Logo
537 people viewed this question
Top Panasonic Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Roger Potts
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
