Question about Eureka 4700A Maxima Bagless Upright Vacuum
Got very loud humming type sound
Vacuum starting making noise i removed the motor but my mother who has alzhiemers moved my parts around and now i have a black app. 4in circle with a hole in the center and a short,tube with a wider flange at top and can't figure out where it goes back on please help thanks
  • Anonymous Jul 19, 2008
    very load roaring
    President:
  • 1,673 Answers
Maybe this picture will help:
Posted on Jan 24, 2008
Loud humming dyson DC07
Hi Phil,
I apologize for our delayed response. I am sorry to hear you are experiencing an unusual noise when you initially run your DC07. Based on the details you provided we would appreciate the opportunity to trouble shoot with you over the phone so we can also hear the noise to better determine next steps.
At your earliest convenience, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Nov 28, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum makes a loud noise like a soccer horn going off, and neighbors are yelling at me for it! how do i make it quiet? its a bissel.
If you haven't changed the belt recently I would try that. Worn belts can cause funny noises sometimes. You can get Bissell replacement belts here:
www.bissellbelts.com
Oct 28, 2009 | Vacuums
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well.
The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
Sep 09, 2009 | Hoover U6630-900 WindTunnel Bagless...
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Apr 13, 2009 | Vacuums
Cyclonic 14.4 volt DustBuster started loud humming noise?!HELP
Ours began making a hideous grinding racket and then quit altogether. Upon disassembly, I found a plastic guard protecting the fan that had warped and was preventing the motor from turning at all. Your problem may be related to the same plastic guard. I removed mine and now all is well...I think. If only I could find a replacement for this little guard. Every online parts distributor I've seen will only go as far as selling filters and prefilters.
Nov 20, 2008 | Black & Decker AV1200 DustBuster Handheld...
Bissell 8990 CleanView Bagless Upright - Loud noise
Sounds like maybe your motor went bad, part # 2031052. Would sell for about $60. When the bearings go bad, they can be real loud as well if the fan on the motor when it gets damaged.
Dec 30, 2007 | Bissell 6590 CleanView Bagless Upright...
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
209 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
