Question about SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player just fell down, after that, when i restarted it it is just showing the blue light but not showing the display on the screen. Any help would be appreciated.
  • nukala_ravi Dec 30, 2008
    Awesome very helpful it started immediately great thanks.
    Problem Solver:
  • 5 Answers
Drop it again from a similar height
OK this is going to be hard to believe....the exact thing happened to mine. It dropped about half a meter onto a concrete floor and showed up with a blue screen and wouldnt shut off.
I unscrewed the back panel and unplugged the battery hoping that it would reset. After several restarts and unplugged batteries it was still unresponsive with the blue screen of death. So like any good tech i tried to reproduce the sequence causing the failure. I dropped it onto my work bench and plugged the battery back in. Worked perfectly after that and has continued to work perfectly since (nearly a year later).
I made sure i covered it with one of those cheap silicone covers after to hopefully absorb some shock after i got it working again. After a year of brutal treatment on military exercises this is the one and only problem i've ever had with my sansa.
Good Luck
Posted on Dec 30, 2008
My Sansa e250 has hanged and only wheel light gets light is I restart the player....Plz help !!
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
push softly but firmly on the Rubber rectangle above the battery (This is the Chip-set For the screen, and memory "Black screen Blue ring" ) and put the back on.
Jul 25, 2010 | SanDisk Sansa e250 MP3 Player
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu button....it shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
The screen on my sansa e260 wont turn on
hold down the power button for 15 seconds and it shoud reset the whole player
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Not charging/ nothing showing up on the screen
Try rebooting, or restarting. Pressing down the reset button for a while, or the play/pause button.
Dec 25, 2008 | SanDisk Sansa e250 MP3 Player
No display on sansa e200
This is a common symptom of defected LCD,you must replaced the LCD so its works better again.
Hope it may help you;
Regards,
VOTIT
Oct 10, 2008 | SanDisk Sansa e250 MP3 Player
No display
Probably hardware damage, but you can try the following "soft" fixes:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player starting problem
Do a Firmware upgrade first - http://www.sandisk.com/sansa/#/support-0/
Enter Sansa e200 series
If this does not work, try the other methods I suggest in my Sansa player "Tips and Tricks" - click on My Profile if you do not see the article in the solutions section (no offense to Fixya, but your website is not yet user-friendly - needs some work).
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player display gone blank
I believe this is answered already. Turn the hold button on. Red light will be on. Hold the rewind button while you insert it into the computer. Please search online this has been answered. I am recalling from what I read a few minutes ago.
Feb 04, 2008 | SanDisk Sansa e250 MP3 Player
HELP ME
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
73 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
