This is a common problem with top load washine machines it is usualy the motor drive coupler.
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
http://www.repairclinic.com/PartDetail/M...
SOURCE: Whirlpool won't spin at high speed
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
SOURCE: Whirlpool Top Load Washer LSR8233JQO no spin & no drain
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949247) and the lid strike will be listed as item number 20 (part #358684). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: top loading whirlpool model lsq9549pw2 will not spin
This is commonly caused by a broken motor coupling. If the washer fills and drains, but will not agitate or spin, the motor coupling is likely the cause. The coupling takes the place of a drive belt and couples the drive motor to the gearcase (transmission). This configuration is known as "direct-drive". The coupling can wear out due to normal wear and tear and easy to replace. The following link explains how:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
This is a very inexpensive repair and its not difficult if you follow the steps provided. The newer replacement couplers are more resilient and resist breaking much better. The part number is included in the link I provided. You can purchase a replacement at appliancepartspros.com for about $11. If you do not wish to order on line, take the part number and go to your nearest appliance parts retailer. This is a very common part that they should carry in their in-store inventory.
If you have any questions about this repair, or if you need additional assistance, plese let me know. I hope you fin dthis information helpful.
SOURCE: My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
