Question about Cobra MR- F55 Base CB Radio
Low transmitting range on Cobra MRF55
The radio worked fine for about 6 months and now I can only transmit about 300-500 feet. All incoming traffic is clear for miles and no problems receiving transmissions, only when I try to call out. Any suggestions? Thanks
  • dstrand Jan 01, 2009
    The radio is in my boat and nothing has been altered or added or deleted. It worked fine for a few months and then just quit transmitting for any kind of distance over 400-500 feet. All incoming transmissions are fine. Thanks again for your help
  • dstrand Jan 02, 2009
    What would some of the other things be?
  • 170 Answers
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Posted on Jan 01, 2009
  • Tom Arsenault
    Tom Arsenault Jan 01, 2009
    Not having the radio in front of me I can only guess. From what your saying, I would say 85% cahnce you blew a final. You probably only pushing 1/4 watt at the driver thats why the short distance.(about 30-60 dollars to fix at a shop)
    There are other things that could cause this but the finals are the most common.
  • Tom Arsenault
    Tom Arsenault Jan 02, 2009
    Voltage to the buffer and or driver and final, A intermitent open at the so-239 ( antenna connector at the pcb, You said the radio is in a boat, could corrosion at the antenna be an issue? How old is the coax? Did the insulating washer on the antenna mount break off? Lots of things to troubleshoot, but very hard not having the radio. Good luck and thanks for using Fixya!
    Happy New Year,
    Tom
My ruberduck was heating
A lot of times if you transmit too long, that can happen. And it eventually can result in blown finals, if you let it go long enough. Make sure your radio is also not transmitting continuously. It probably isn't, but both look at the display for an indicator (you could be laying it down in such a way that it will do that)...tune another radio to the same frequency. Sometimes a defective antenna will cause that, as well.
Jun 10, 2014 | Cobra MRF55 2-Way Radio
Cobra vhf will transmit but sounds very muffled or weak. Sounds like I'm several feet away from mic. I receive fine. Just transmitting problems. I have already replaced mic
I have the same problem with my midland 9001z.I've changed the mic,the coax the antenna the only thing I haven't done is on the inside.I don't want to tackle that until I get a service manual for it. Now what kind of cobra are we talking about?
Apr 29, 2014 | Radio Communications
Cobra microtallk PR 240-2 radios. One of the radios transmits and receives on a frequency one channel less than the selected/displayed channel. That is, if channel 7 (462.7125 MHz) is displayed, the...
I'm looking at a price range somewhere in the area of 40 - 120 $$ to buy them new. If YOU can fix them without getting a tech involved then go for it but you will need a frequency counter that covers the range and they don't give them away cheap and the repair cost wouldn't be cheap either. I would buy another pair.
Oct 13, 2013 | Cobra Radio Communications
Do i need ariel for cobra MR F55 EU radio
? I assume you are asking if you need an ariel antenna for this radio in order to receive and transmit? if that is the case then yes you do, Any radio requires a matched antenna in order to transmit, if you were to transmit without an antenna, most of the RF energy will transfer back into the radio and over heat "burn out" the output transistors. always make sure to have a proper antenna connected before transmitting on any radio.
Jun 19, 2011 | Cobra MRF55 2-Way Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Antenna mounting
according to FCC rules RULE 8 - Antenna Height
{A} "Antenna" means the radiating system (for transmitting, receiving or both) and the structure holding it up (tower, pole or mast). It also means everything else attached to the radiating system and the structure.
{B} If your antenna is mounted on a hand-held portable unit, none of the following limitations apply;
{C} If your antenna is installed at a fixed location (whether receiving, transmitting or both) it must comply with EITHER one of the following:
[1] The highest point must not be more than 20 feet (6.10 meters) higher than the highest point of the building or tree on which it is mounted;
or
[2] The highest point must not be more than 60 feet (18.3 meters) above the ground.
{D} If your CB station is located near an airport, and if your antenna structure is more than 20 feet (6.10 meters) high, you may have to obey additional restrictions. The highest point of your antenna must not exceed 39.37 inches (1 meter) above the airport elevation for every 109.36 yards (100 meters, 1 hectometer) of distance from the nearest point of the nearest airport runway. Differences in ground elevation between your antenna and the airport runway may complicate this formula. If your CB station is near an airport, you may contact the nearest FCC field office for a worksheet to help you figure the maximum allowable height for your antenna.
Jul 20, 2009 | Cobra MRF55 2-Way Radio
Won't receive audio or any noise with squelch all the way left
Perhaps a faulty connector on your coax cable. Get it fixed or replaced you coax cable with a new one.
Mar 24, 2009 | Cobra 19 Ultra II CB Radio
My ranger 2950 will receive but will not transmit, also where can i get a 6 pin mike for this same radio ?
check tr 51 (Q 51) the sb754 on the back side mounting of the radio.. the center pin (collector) of this modulator ic should not be 13 volts. my bet is that it is.. this test is done in am mode.. not sideband.
depending on you carrier setiing it should be between 3 -8 volts any higher in am mode and my bet is that its bad... much more common than the finals in this radio. good luck Rick
Dec 13, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Not real sure
Make sure that the mike gain & RF gain controls are turned clockwise & the squelch is counter-clockwise.
Jun 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra MR- F55 Base CB Radio Logo
180 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
