Question about RCA HD52W59 HDTV Projection Television
Picture looks like 3D without 3D glasses on???
My TV was working fine last night, and then this morning, when I turned it on, the picture is distorted. I can explain it as looking like a 3D movie. The way the screen looks if you take off your 3D glasses. If I was looking at the letter A in the bottom corner, there would be 3 of them, one green, one blue, and one red. This is basically how the whole screen looks. In the center of the screen, it almost is clear (not quite), and as you go toward the corners, it gets more distorted. Please let me know if more description or info is needed. Thanks! I my tv looks 3d-ish and dips on the top and the bottom...I have a hdtv rca 55' got an estimate of 200-300$ does that seem resonable?
  • nicolek80 Jan 02, 2009
    I HAVE THE SAME EXACT PROBLEM BUT WITH A 52 INCH LET ME KNOW IF YA GET A SOLUTION...
    Scholar:
  • 90 Answers
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Posted on Jan 02, 2009
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
What to do when your Toshiba 55TL515U powers on, works fine for a few hours, then suddenly turns off, and then continues to click as if it is turning on and off again?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 11, 2017 | Toshiba 55TL515U 3D LCD TV
Can you repair a 24 inch BUSH smart TV/DVD.
Main power supply regulator board (SMPS board) fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name of your device in the search box at the top of the home page, to get gathered all the related posts.
Jan 09, 2017 | Bush Televison & Video
24inch Bush smart TV/DVD not working.
Could be an open internal fuse or power supply failure
Black screen, green light on the bottom is on, electric plug is on house plug, no picture, was working fine last night, now only black screen!
Do a hard reset to this set, and then check. If it do not help you, check and replace its main digital board. It will be faulty.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 08, 2017 | Televison & Video
How to watch 3D movies
Use a 3D spectacle to feel it better.
Jan 08, 2017 | Samsung Televison & Video
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
I have a bell satellite reciever, I am trying to hook up a second tv to the hdmi output, I hooked up a hdmi splitter! but it does not seem to work. I get a picture on only one tv and no sound. when I...
NO YOURE NOT WASTING YOURE TIME YOU JUST NEED TO PUT THE MAIN CABLE FROM THE STAELLITE INTO TO WHERE IT SAYS IN AND THE OTHERS CABLES IN WHERE IT SAYS OUT AND OUT AGAIN
Apr 21, 2011 | Toshiba 26HF85 26 in. Television
RCA HD52W59 HDTV Projection Television Logo
382 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
