Question about Air Tools & Compressors
Low air pressure
Campbell Hausfeld FP200300AV compressor. I've only used it 4-5 times. Bought at WalMart and way ouit of warranty.
Now I can only get 25 PSI from the unit. This unit has a regulator.
Any suggestions?
Tim in Tampa
  • ian stalker May 11, 2010
    hi is the 25psi in the tank or after the regulator?
Take the compreessor apart and clean the reeds with a piece of emory cloth, this shoud help.
Posted on Jan 19, 2009
    President:
  • 1,388 Answers
I have worked on several of these little compressors and have found that they suffer from early failure of the cylinder and piston. However, you could check a few things for other problems that I have seen on low volume compressors. While the compressor is running spray soapy water on the airlines and drain valve to make sure that they are not leaking. A small leak will prevent the unit from reaching cutout limit. Remove the pressure regulator and attach hose directly to fitting to make sure the problem is not faulty regulator. I have not been able to find parts for this unit. Good luck, happy new year!
Posted on Dec 31, 2008
I would like a wiring diagram for model #FP200300AV serial #00174170
You can try finding it here but you may need to send an email to the company and request the wiring diagram. I could not find one online for you.
http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?storeId=10051&catalogId=10001&langId=-1
Jul 13, 2011 | Campbell Hausfeld 2 Gallon Air Compressor
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
My compressor stoppped running. i found a burned out fuse inside. i've replaced the fuse. the fuse was labeled 3a250v. thats what i replced it with. when i turn it on the fuse blows immediately. on some...
Every time I connect my Campbell & Hausfeld fp200300av Compressor and push the power on, the fuse blows. Even if I disconnect the motor from the circuit board the fuse continues to blow. Then I extracted the Rectifier-diode (the black and square with a hole electronic with four stands part).
This piece was the reason of the short circuit, I replace it with an equivalent one and I accomodate it to the right terminals in the circuit board. My compressor works flawlessly again!
Sep 24, 2009 | Campbell Hausfeld Air Tools & Compressors
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Air Tools & Compressors Logo
313 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
