Question about Pinnacle Dazzle DVD Recorder
Pinnacle Dazzle DVD Recorder software
Installed the software successfully. Started running the recommended walk-thru with "Wizard". Could not access the "time" button when asked for time. The "start recording" button returns me to the time button that isn't active. What do I do?
    Novelist:
  • 176 Answers
Uninstall, reboot and reinstall making sure selections or options for configuration are correct
Posted on Jan 01, 2009
Burn error Instant Dvd Recorder windows 7 Dazzle dvc 100
Set the compatibility back to windows 7 and then uninstall the program and all of it's drivers, then reinstall it and see if it works then.
Jun 08, 2012 | Pinnacle Dazzle DVD Recorder
I have pinnacle dvd recorder, in step 1 i dont have the option to select dazzle dvd i only have pinnacle file capture therefore i cant get my vhs to transferr
Hi lloyd_kin466
I'm not familiar with Pinnacle stuff but in any capture software , you need to customize the capture options . Set the system to PAL or to NTSC , select the entry . If you are reading from a VHS device , select " composite " and not TV ... etc ... It should work unless your software hasn't been correctly installed or is not compatible with your OS .
Best regards ,
fanaudi .
Aug 31, 2011 | Pinnacle Dazzle DVD Recorder
Given a dazzle pinnacle instant DVD recorder GmbH 2006 but only comes with windows software I have a Mac 10.6how can I get the software to make it go
There are different émulators for mac to run PC software Parallels Desktop , VMware Fusion, Apple BootCamp, CrossOverMac but those software are not free you have to buy them
Jul 22, 2011 | Pinnacle Dazzle DVD Recorder
I have dazzle DVC 170 Rev. 1.2. this came with the CDs for Windows XP. My new laptop (Compaq 621) is with Windows 7, I downloaded the Instant DVD Recorder. Installed it and then loaded the Pinnacle Studio...
one of the drivers is not compatible or unstable with you system. make sure you have the relevant firmware on your system, update the drivers from the driver menu that is in device manager win 10 its right click on windows logo (start) bottom left and click on the driver and update before using it if no update is available you could try the properties of the software. right click on the icon for the software and menu will pop up go to properties click on that and then go to menu compatibility and click to run on win xp mode or another mode. then press ok.
Jun 02, 2017 | Pinnacle Dazzle DVD Recorder
My pinnacle instant dvd recorder freezes. it says burning error when i try to record, then my computer goes to the blue screen and restarts. i use vista. what is going on? why won't it work? the dazzle dvd...
The blue screen is referred to in the industry as BSOD( blue screen of death ) this is a stop screen that is built into Windows to halt on errors whether its a hardware malfunction or incompatibility or software conflicts. Your Dazzle could be faulty or the software is causing the halt screen. This is a major problem with Vista. I have changed most of my computers from Vista back to XP because my Dazzle and new video cam won't run on Vista but runs excellent on the same machine once switched over to XP. Good luck and fell free to Google BSOD for more info.
Jan 31, 2010 | Pinnacle Dazzle DVD Recorder
I have dazzle dvd recorder for windows. I now use a Macbook!
Hi and welcome to Fixyah,
Dazzle DVD for windows can used only if you are windows system but for mac there is no particular driver or even the software to download. The product for MAC is Pinnacle video capture for mac which is the software is already included.
Jan 29, 2010 | Pinnacle Dazzle DVD Recorder
Pinnacle dazzle DVD recorder issues
You need to return your product because that device is defected. If you buy that on best buy return it to them and asked for replacement.
Jun 11, 2009 | Pinnacle Dazzle DVD Recorder
Dazzle will only rcord 103 minutes and movies are 120
Are you on Windows? What version (XP, 98, Vista, etc?)
What file system are you using (right click on the drive in My Computer and select Properties)
If you are using FAT32, there is a built in limit to 2GB files. If you are finding that your capture is hitting 2GB (=103min?) and then crashing, this may be your problem. Also, consult the capture settings in the Dazzle software and ensure no file size or running time limitation is selected there.
Jan 03, 2009 | Pinnacle Dazzle DVD Recorder
Pinnale Dazzle DVD recorder doesn't recognize VCR
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
Dec 09, 2008 | Pinnacle Dazzle DVD Recorder
Pinnacle Dazzle DVD Recorder Logo
16 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
