Question about Matsonic MS9087C Motherboard
Same problem I have a MS9087c motherboard and just picked up a SATA blu-day drive. I am having a hard time getting it to recognize the drive. Boot ups are taking 10 minutes. Have you been able to fix your problem?
    Genius:
  • 1,061 Answers
Sata drivers are incorreact or corruted uninstall and reinstall new from msi web site.http://www.msicomputer.com/product/p_search.aspRICHARDM69
Posted on Jan 03, 2009
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
I need some help...A friends laptop is very messed up, i need to install his SATA Hard drive on my computer. I have a SATA Hookup on it, its all hooked up, but WindowsXP is not recognizing it. My brother...
Hi
Thank you for your query
From what you are describing you are missing the SATA controller
Please do the following
1) Go to www.devicedoctor.com and download and install application
2) Once installed load up and click on begin scan
3) Once it has scanned it will probably pick up missing SATA controller and give you the option to download
4) Download the SATA controller and install
5) Reboot PC and the SATA drive should be recognised
Mar 12, 2010 | EliteGroup P4M800-M7 Motherboard
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Sata drive not recognized at boot up
I HAVE UPLOADED THE MANUAL HERE, IF YOU DON'T WANT TO WAIT THEN GET INTO YOUR BIOS BY DOING A HARD BOOT AND HITTING THE DELETE BUTTON ON START-UP.IF THE MOTHERBOARD SUPPORTS SATA , TO WHICH I FOUND NO CONFIRMATION , YOU CAN CHANGE IT BY GOING INTO THE ADVANCED SETUP PAGE AND CHANGE THE FIRST BOOT DEVICE TO SATA RATHER THAN IDE. YOU WILL ALSO WANT TO CHECK THE PCI SETTINGS AS WELL FOR YOUR CONTRLOLLER CARD ....GOOD LUCK
Jun 02, 2009 | PC Chips M825G Motherboard
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
Computer will not boot with Pioner Blu-Ray BDC-SO2 installed.
Hi stokarek,
With respect to SATA drives. All are master drives. As you mentioned if there is a fight between drives the trouble can be settled in the bios. I gather the WD160GB drive holds windows on it & the WD is connected to SATA 1 port. Enter you're bios & go to the Boot section. Open you're manual to section 2.6 boot menu page 2-32. Make sure you're WD is the only hard disk drive listed. After you add the Blu-Ray (To SATA 2 port), (its pin setting should be set as master. Than go back to the boot menu & make sure the Blu-Ray drive is listed under the WD drive.
Keep in mind for the future that if you want to boot to the Blu-Ray drive you'll need to press the F8 key at boot up. Windows select boot device window will open & high-light the Blu-Ray & press enter so the Blu-Ray will boot. Windows should no longer stall. If this does not work try switching the pin on the blu-ray to slave. (I'm not sure there is even a pin setting on the blu-ray drive. Never the less the bios boot order is the boss.
Link to Asus main driver site for ASUS M2N8-VMX
http://support.asus.com/download/download.aspx?modelname=M2N8-VMX&SLanguage=en-us
Good Luck stokarek!
Mike
Jul 08, 2008 | Acer AOpen MX 3ZA (91.88110.101)...
Disk boot failure when I installed a new SATA DVD writer
Start the system & enter you're bios & use you're manual to help guide you on this. Go to the Boot section of the bios. You can set the boot order. Normal boot order is like this:
1st boot device, floppy disk (if one is connected).
2nd boot device, cdrom drive
3rd boot device, hard drive
(Drive the has windows installed on it).
Save & exit the bios. The system will restart & windows should load. If it does not, than you picked the wrong hard drive.
Mike
Jun 17, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Matsonic MS9087C Motherboard Logo
67 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
