Question about Crosley CDG6000 Gas Dryer
Belt replacement on crosley gas dryer cdg6000w
What is the best way to go about taking the dryer apart to replace the belt?
thanks
james
  • Anonymous Apr 29, 2009
    what is the best way to go about taking the dryer apart to replace the gas coil valve on a kenmore
  • Mark Nichols May 11, 2010
    go to whirlpoolpartssurplus.com call me for free and i can take you step by step,....
3 Suggested Answers
SOURCE: crosley CDE6500W
This will show you the parts diagram. You can do it from there.
http://www.partselect.com/MultiModels.aspx?ModelNum=CDE6000&searchTerm=&RefineSearch=0
Posted on Feb 01, 2008
aborcass
  • 2651 Answers
SOURCE: my dryer isn't drying my clothes!
soundsmore like a coil kit thats gone bad,located atop the gas valve assy istelf, part number 279834 retails for about $20
Posted on Nov 09, 2008
jeffsterrett
  • 98 Answers
SOURCE: How do I get to
UNPLUG THE DRIER BEFORE DOING ANY OF THIS!!!!
You need to lift the top up to get to the screws that hold the front on. To get the top up, are 2 spring-loaded clips that need to be pushed in to release. Slide a putty knife in the gap between the top and front, right in the middle. Slide to the left till you hit the clip (it's pretty obvious when you hit it). Now pull out the putty knife and press in on the clip, through the gap, from the front. It should release and allow you tpull the top up in that corner. Repeat the process on the right side.
Once both clips are released, the top should come up, pivoting in the back.
Now for the front:
There are two main types of fronts used on whirlpools (crosley is made by whirlpool).
If your front panel is all one piece, there will be 2 5/16" screws in the inside top corners, take these screws out and the front should pivot forward. Unhook any wires and pull the front off the two metal tabs that retain the bottom. The belt is on a springloaded tensioner near the motor. Release the tensioner and pull the drum and belt out together. Reverse to reinstall.
If your front panel has two pieces, you will need to remove the bottom (smaller) panel by releasing the two retaining clips. They will be located in the gap between the two front panels, you can locate them basically the same way you did for the top. Once released, pivot the panel out and lift it off the bottom retaining clips. Now you will have 4 screws to remove to get the main front panel off, as well as any wiring. Once you get the front panel off, take the belt off the tensioner and pull the drum/belt out. Reverse to install.
Also, while you're in there, vacuum out any dust you can, and if you're feeling ambitious your can also grease the rollers for the drum.
Hope this helped, lemme know if you need any clarification.
Posted on Sep 15, 2011
Why do i have a loud clanking noise when my dryer starts and ends cycle?
Good Afternoon Friend, thank you for your post!
I see that your question is listed under Crosley dryer. From what you have described it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website. Best regards! - Z
May 04, 2014 | Crosley Clothes Dryer Tension Pulley...
Crosley cdg6000w
Here is the propane conversion kit for that model. The kit comes with instructions.
Nov 24, 2012 | Crosley CDG6000 Gas Dryer
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
My dryer isn't drying my clothes!
Nov 09, 2008 | Crosley CDG6000 Gas Dryer
Crosley dryer
How to replace belt on crosley cdg6000w gas dryer?
Sep 05, 2008 | Crosley CDG6000 Gas Dryer
Crosley CDG6000 Gas Dryer Logo
144 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
