Question about Kodak EasyShare One Digital Camera
Camera keeps turning itself off even with new batteries
    Genius:
  • Kodak Master
  • 1,019 Answers
Then it is time for the repair shop. no user fix here.
Posted on Jan 24, 2013
3 Suggested Answers
SOURCE:
SOURCE: camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Posted on Feb 07, 2009
SOURCE: Camera will not stay on
when the len's comes out, try cleaning the glass part of the shutter with your shirt or a clean cloth. This worked for me.
Posted on Jul 13, 2010
Battery keeps dying even though its charged
maybe you need a new battery. They have a specific life.
if the problem is with the camera itself, then it is probably the master board - and you might consider whether Nikon repair is worth the cost.
Feb 10, 2018 | Nikon Coolpix 7900 Digital Camera
Camera won't turn on? i even installed new batteries.
Hi. Remove those new batteries and use the eraser end of a common pencil to clean the battery contacts within the camera itself. Then reinstall the batteries. If it still will not start have the "new" batteries tested at a radio shack store, they do this for free. Joe
4 thumbs up please. ty.
Nov 03, 2010 | DXG Technology DXG-503 Digital Camera
My nikon coolpix s570 keeps giving me a waring that says "battery temperature too high" and the camera won't even turn on
The camera will turn itself off if it thinks the battery is too hot.
The manual just says to turn the camera off and allow the battery to cool down.
It is not right for this to keep happening.
If possible I would return the camer to the store and tell them about it, it may need a repair.
You may like to see if it is better with another battery.
Hope this help a bit.
Mar 05, 2010 | Nikon COOLPIX S570 Digital Camera
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera keeps shutting off, even with new batteries.
It could be something more serious, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 02, 2009 | Kodak Digital Science DC210 Plus Digital...
When I turn on my camera it automatically turns by itself with new batteries
Are you still using alkaline batteries (or worse yet "Super Heavy Duty")? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera.
Digital cameras for the most part should be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Oct 19, 2008 | Cameras
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
Camera turns itself off while i am using movie mode
Use alkaline batteries like duracell. Digital cameras support only extra duty batteries.
May 04, 2008 | Canon PowerShot SX100 IS Digital Camera
Resolution
No, it resets itself because it is an older camera.Most older cameras will, once turned off, return to their original settings.
So, if you want it to be 76 frames, you will have to do that each time you turn on your camera.
Mar 25, 2008 | Olympus Camedia C-350 Digital Camera
Kodak EasyShare One Digital Camera Logo
29 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
