Question about Bose Lifestyle 48 Series III DVD Home Entertainment System - White
No voices play through DVD application of Lifestyle 48 III
Sound effects and music are perfect, but human voices are nearly inaudible and sound as if they are playing at a 'slow speed,' ie a 45 rpm playing at 33 rpm.
  • swansea382 Jan 01, 2009
    Worked! Thanks.
    Wiring was correct, turned off unit (over night). Started unit, worked fine.
    Great website
    Turning off unit for seveal hours and then starting up (rebooting) did the trick. great web site.
    Thanks as it saved me a couple hundred dollars for a company to come out to diagnose and fix.
  • 10,594 Answers
Go to DVD Player setup menu and select Stereo Out sound option.
Human voices are not coming because DVD is may be set on Dolby Pro Logic, DTS etc
Posted on Dec 30, 2008
  • 13,433 Answers
Are the human sounds coming from a dvd or are you using a microphone? the microphone might be faulty.
    Sergeant:
    Champion:
  • 304 Answers
Have you try resetting the unit. unplugging it into the electrical outlet for an hour,
also do check all wrong output input connections from the unit.
My bose lifestyle 48 say resolutio not supported when i try to play a dvd but i have sound without a picture. how can this be fixed
Is it a copied DVD or DVD-R / RW? If if says resolution not supported then it means that the DVD has a video format that cannot be played on the Bose even though the sound track is fine. The DVD may work fine on a PC as these can usually play more file types, but it could be a number of things causing it not to work and unfortunatetly there is nothing you can do.
Jun 29, 2014 | Bose Lifestyle 48 System
Connecting optical cabel to ps3 and no sound
go to the setting on the ps3 and go to audi select the audio to play through optical
if this does not fix it then
make sure that the bose is in the correct mode to play through optical
Jan 14, 2010 | Bose Lifestyle 48 Series III System
No sound in left side speakers
Swap the left and right cables to see if it's in the Bose or in the TV.
Nov 28, 2009 | Bose Lifestyle 48 System
We want to hook up an HDMI dvd player to the tv and have the sound come thru the Bose Lifestyle 38 (older model, did not come w/the HDMI converter that the 48 has or newer systems come with). We are not...
The best way to do this is to take your OPTICAL AUDIO OUT from your TV - (if it's a newer TV) - plug it in to the OPTICAL AUDIO IN on your BOSE system, then use the 'TV' source on your Lifestyle 38 to get the sound from. I have sound for X-Box, DVD player, Blue-Ray Player and Wii being pushed through the TV back to the BOSE and it sounds great. I don't have to change the source on the BOSE very much either - except when I listen to stored music!
Sep 27, 2009 | Bose Lifestyle 38 System
Sound only from disc in unit
i will tell you to contact Bose I had a small problem with my bose system had to send it back they fixed it for free and extended my warrenty from day one. yop bought bose for a reason and they are a great company used there service they have always been great. I whis i knew how to help you with that I havent had any experiance with there 48 system and digital recorded data systems. but would bet that it is a problem that is more than simple. when a bose breakes it is normally major thay make really good stuff, pricey but good
Jun 27, 2009 | Bose Lifestyle 48 System
When watching a DVD, the surround sound plays all background music but the actors voices are not heard - can hear music and voices in 2 speaker only - TV programs play in 2, 3, and 5 speaker mode.
If there is nothing at all from the center channel while watching a DVD, first try resetting the system (unplug the power cord from the sub, and the DC power cord from the media center for 30+ seconds) If a reset doesn't help this, run the "adaptIQ" setup disc again. Honestly, this is a very odd problem for that system to have. (especially since we know the center speaker works for other sources) I hope this helps.
Jun 20, 2009 | Bose Lifestyle 28 System
Sound just stopped
You need to replace the audio amplifier IC´s because maybe are damaged
Nov 17, 2008 | Bose Lifestyle 48 System
Only sound for cd/dvd
Could be damaged cable between the media centre and bass module (check along cable length for damage, kinks or at DIN plug ends for bent/damaged pins), faulty media centre (unlikely) or fault in the bass module....
Jan 13, 2008 | Bose Lifestyle 48 System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 48 Series III DVD Home Entertainment System - White Logo
60 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
