Question about Frigidaire GLTR1670A Front Load Washer
Tub bearing is making grining noise
Repair man said it was due to not using HE laundry detergent yet my manual says nothing about this, Its a 2004 model. Has anyone else had a problem with this and did Frigidaire stand behind their product? The repair tech said the soap scum left behind with the regular detergent builds up on the rear bearing and destroys it. So now I have a 3 year old washer that to fix is about $450 when I paid just over $500 for.
  • Anonymous Jan 08, 2009
    Our washer is five years old, two person household, used three times per week. Bearing is geeting worse and worse. Appears to be a common problem. Mfg. won't stand behind their product.
  • 318 Answers
Yes when the washer sounds like an airplane taking off during the spin cycle, it is a worn rear bearing.
it does happen from the wrong type of soap being used. the suds from regular soap will destroy the seal and allow water to get into the rear bearings causing the bearing to fail and become noisy.
HE type soaps have been recommended by the manufacturer for about 6-7 years now and you MUST use them to prevent this from happening. it can also happen with HE is you just use too much.
now the good news... the inner tub has a lifetime warranty but the outertub, comes with seals and bearings, may only have a 5 year part only warranty.
what you can do is to call frigidaire at the 800# and ask if they can check the warranty for you. a 3 year old and a 5 year old unit might be covered by a part warranty. if so then the labor to replace the tubs will be about 200-300 bucks. i know its a pricey repair but is certainly cheaper then buying a new washer.
by the way, all front load washers will do this if you use the wrong soap.
Posted on Jan 15, 2009
I have a Kenmore series 600 washer which leaves white residue on laundry. I've tried using less detergent (only use liquid detergent) but it still happens. Using Tide detergent.
There are a lot of causes for that issue. Overloading, too much softener, bad drain pump, dirty drum, hard water are some of the more common ones.
Jan 11, 2017 | Kenmore Washing Machines
If I use it everyday it's fine. If it sits a week, it makes a loud squeal during the first one or two agitation cycles. What is likely cause?
Hello. I need the model number to help you accurately. If this is a top loading unit, the problem sounds like the transmission or if it's a certain model I'm thinking of, there is an electric mode shifter that causes this symptom. What happens is this: On some top load models, there is a rubber seal located in the center of the tub, underneath the washer. If this seal should leak, water, with detergent, dribbles straight down into the electric shifter or the transmission, dissolving the high temp, long-lasting grease there. From that point, the clock is ticking until it has metal on metal operation from the bearings. Similar symptoms occur with front-loaders--the rear tub seal leaks, water/detergent gets into the bearings and causes the infamous "jet aircraft taking off or freight train in the laundry room roaring sound". In either case, it will be a MAJOR repair, requiring total disassembly/re-assembly of the washer.
Sep 07, 2015 | Washing Machines
Interior ring deteriorating
I suspect it's the aluminum spider arm that spins the back of the tub. The moist environment and the ionizing laundry detergent causes a chemical reaction that corrodes this easily and it breaks. It is covered under a lifetime warranty, so call Whirlpool and ask them to send the whole tub unit (the spider arm is attached via machineshop). You will need c-clip pliars to DIY or have a serviceman install it, and be sure to label the clips for when you put them back. This happened to us. The seal is part of the tub unit. Good luck!
Jan 25, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My GE Profile washing machine leaves soap suds in the bottom and on the clothes. I use Cheer liquid detergent. My husband says it is because of placing too heavy of items, such as towels, in the machine....
Use ONLY the recommended amount of detergent per the label on the detergent.
Pour detergent in the tub first then start the water,then add the laundry.
Do not overload the machine.
Use a bathroom scale to weigh 12-15 pounds of laundry and no more.
Big tubs invite more laundry.
Don't be fooled by a big tub.
Feb 20, 2011 | GE Washing Machines
Washing machine making loud rattling noises and smells of burning rubber
Your washing machine has a belt on a pulley and that belt is being stretched. That belt is attached to a motor that turns your laundry tub. Your washer if out of balance will shake and rattle and the tub might be locked in place and the motor is forcing the belt to turn but the tub is not turning. If you are not mechanically inclined call a washer service repair man.
Oct 01, 2009 | Admiral Washing Machines
Maytag EpicZ Washing machine; basket drive pulley noise & wobbly
sounds like a bad bearing...here is how I check them open the door .lift up on the tub if any play in the upwared monment it's bad...you can also remove belt and pulley spin the tub if you still hear the noise it's bad....
if bad you will have to replace rear outer tub and spinner (it has the shaft on it)
also Give Maytag a call at customer relatiions...make a lot of noise they may just give you the repair..
Sep 21, 2009 | Maytag EPICz 3.7 cu. ft. Washer
Using reg detergent in Cabrio He cause problems?
yes you do need to use HE soap in your unit. the he type soap is a low sudsing and the reg soap will cause the unit to not rinse out and could cause it to not spin properly. the noise you are hearing is probably something n the pump and if it doesnt go away after a few loads, then you should try to check the drain line going into the drain pump. it could have something causing the noise.
otherwise you could have a spin bearing making noise. its not as likely but could happen after a year or two of using the wrong soap. the wrong soap will ruin the seals and let water into the tub bearings and that will cause them to wear and make noise.
keep running it and get back to us if you still need more help.
thanks tzweeb
Feb 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dark brown stains
Try running a cycle on hot with 1/2 cup dishwasher detergent (powdered) in it. Stop it before it pumps it out and restart again, Do this a few times to get a long scrub action. I don't think its oil as a front load machine doesn't have a transmission. If you think this is a rust stain use a rust remover type product instead of dishwasher detergent.
Jun 07, 2008 | Frigidaire GLTR1670A Front Load Washer
VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
173 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
