Question about Brother IntelliFAX 2800 Laser Fax
Not receiving any faxes.
The fax machine has been ringing but no faxes come through. On the display we see the letter MLN.
Line not workimg,and put fax mode and checkreceiving kbps 1500
Posted on Jan 01, 2009
How activate auto answer?
1 Press {AUTO ANSWER} repeatedly to display the following.
FAX ONLY MODE 3 RINGS
The display will show the ring setting in FAX ONLY mode.
The {AUTO ANSWER} light is ON.
2 If you wish to change the ring setting, press
{A} or {B} repeatedly to display the desired
setting, and press {SET}.
How faxes are received
When receiving calls, the unit will automatically
answer all calls and only receive fax documents.
Mar 08, 2012 | Panasonic KX-FL611 Plain Paper Laser Fax
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
I cannot receive faxes. The machine rings, the
check to see how the rx mode is set up as it may be set to manual it should be auto.. this means if a fax comes in you will have to lift phone or pressthe start button to receive the fax in manual mode whereas the auto or fax mode will turn the fax on automatically
Aug 13, 2009 | Office Equipment & Supplies
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Fax machine won't receive without pick up phone receiver.
on the front display you will see a recieve button and you need to press this and you will see on the display it say either fax...fax/tel.. auto press the button until fax shows thsi means it is only being used as a fax so the line will auto pick up... if you set it to auto it will ring check the line and if it finds its a fax it will put it through as one if not it will ring you phone.. good luck
Jun 26, 2009 | Brother IntelliFax-4100e Fax
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Not sure how to setup the tel/fax mode correctly
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 31, 2008 | Canon FAX-JX200
Can't get this fax machine to work with my answering machine
I have the same problem. I can send a fax, but if I try to receive a fax, the distinctive ring goes off, and it says RECEIVE on the display, but it doesn't receive anything, and there is nothing in the memory. Any ideas? PLEASE HELP!!!!!
May 24, 2008 | HP 640 Inkjet Fax Machine
Brother IntelliFAX 2800 Laser Fax Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
