Question about GE JKP45 Electric Double Oven
JKP45 lower oven does not work.
I heard that using a manual reset could resolve the problem.
Where is the lower oven reset switch located exactly?I KNOW there is a reset button; because that's how it got fixed before. Really simple, but I can't remember how to find it!! Anyone know?
    Genius:
  • 1,665 Answers
Hi!
At link below you can see your online user manual. Have a look if it may be helpfull.
http://www.fixya.com/support/p126967-ge_jkp45_electric_double_oven/manual-12202
Posted on Jan 16, 2009
    Sergeant:
  • 221 Answers
Its located behind the vent grill that is the reset switch.
Posted on Jan 14, 2009
    President:
  • 2,110 Answers
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
    Genius:
  • 2,035 Answers
Try to reset the breaker by turning it off, then back on again.
OR try this
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
  • Good luck...
Posted on Dec 30, 2008
  • 470 Answers
If you have a relatively new Lacanche range, your electric oven reset switch can be. accessed by removing the electric oven vent cover ,then kindly switch the oven inside,
    Genius:
  • 1,550 Answers
Try holding the door light switch in while the door is open, put the range into clean while you hold the light switch in. The lock arm should move into the lock position, you have to keep holding the door light switch in through this whole process. After the door locks, still holding the light switch in, cancel clean and the door should unlock. After the door lock motor has quit running, you can release the door light switch and the oven should be reset.
    Genius:
  • 1,913 Answers
Check on left pane it is on that find in back side also u can see reset swithc .
u can do it come on.
I have a GE JKP45 Double Wall Oven. The upper oven stopped working after the self-clean cycle completed. There are no errors showing on the control panel. The lock circuit thermal switch located behind...
the bimetals you checked, did you remove them from the circuit before checking? if all of the thermals, not going to a fan are closed, then you have either a control problem or an element. after self cleaning usually the HIGH LIMIT thermal opens, and is a simple replacement. but if all are good then you need to look deeper. there should be an tech sheet in the control top or control panel area that can help you trouble shoot.
Feb 04, 2012 | Ovens
Oven is display F-1, what the problem? Model JKP45
Hi
Thanks for using FixYa. Error F1 in your GE Electric Double oven means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 23, 2010 | GE JKP45 Electric Double Oven
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
Cant read control panel. LED is very dim JKP45
Ordered a new panel . Control panel is not serviceable
Oct 12, 2009 | GE JKP45 Electric Double Oven
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
GE double oven - bottem will not heat, top oven fine
Good Luck, DVS1936
Oct 05, 2008 | GE JKP45 Electric Double Oven
Heating element
the chances are the top oven thermostat has gone and may need replacing. also check on any selector switches relating to the top oven unit they can burn out on the contacts. there is no seperate fuse.
Jan 20, 2008 | GE JKP45 Electric Double Oven
Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Aug 09, 2007 | GE JKP45 Electric Double Oven
After Self-Cleaning the lower oven wont heat up!
There is an overheat sensor that may have failed to the open position. It is a little round button thing a little larger in diameter than a dime with two wires. Check to see if it is in the open position
Jul 30, 2007 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
138 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
