Question about Samsung HP-R4252 42 in. Plasma HDTV
No power/picture Samsung Plasma TV Model HP-S4253 Removed back cover, fuse on Power supply board was blown. Replaced fuse, when powered up one of the large copper coils started to glow, powered off. I wanted to know if this is a power supply problem or another board so I can replace it. I have limited electronic knowledge. Scale of 1-10 about a 4 P.S. Model # below was closest I could get. Correct Model above. Power Board Model # PSPF391A01A
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
circuitworld
  • 335 Answers
SOURCE: Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Posted on Nov 03, 2009
Testimonial: "Thank you. your feedback was appreciated. Theres a lot of value in getting an expert opinion whether to fix or not to fix."
  • 2427 Answers
SOURCE: Whats involved in installing a
hmmmm its easy really..
  • unscrew rear cover
  • cables from power board to other components
  • unscrew and remove power board
  • put in new board and screw down
  • re connect cables
  • screw back on the rear panel
  • plug in
  • turn on
  • watch!!
Posted on Sep 14, 2010
Testimonial: "Thanks for the easy fix!"
SOURCE: power light comes on and clicking is heard but no
your problem is more a defective y board with y buffer boards one of them is short
Posted on Oct 26, 2010
  • 8457 Answers
SOURCE: My samsung hl56a650 tv power cycled and then
Likely the whole power supply board it is shot,dying capacitors alone will not emmtting smoke out of the tv.
Posted on Jan 10, 2011
Testimonial: "Thanks a lot for your answers."
How to troubleshoot Samsung plasma TV with no video.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 01, 2015 | Samsung Televison & Video
I have a samsung 50 inch plasma TV and it has no picture, the screen is blank and no light on the screen, we have no idea what is wrong if you could help would be great, Thanks.
Hi Its means that your television have no power.Maybe the power supply is dead.Its better to repair the power supply.If you have knowledge in TV,will you remove the back cover and check the power supply.Check the fuse if blown and check if the capacitors is leaked.
Jul 16, 2011 | Samsung 50 in. Plasma TV
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
Samsung model HP-T5054 Plasma TV .. Push power button it lights up and Tv clicks like it is comeing on but then dont..
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Just clicks
There are many reasons to cause the TV clicks.
Power supply board failure
Y board and buffers are defective
Mainboard is defective.
If you want DIY, open the back cover then check those fuses on the power supply board - this board has the power plug comes in. Then check Va, Vs in comparision with label sticked on the back panel. If Va, Vs does not have there, replace the power supply. If yes, you may unplug the cable which is connected to Y board and buffers-power on and see Va, Vs has any change. If yes, the Y board and buffers need replaced.
Aug 12, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
42'' Samsung Plasma Tv Screen went black but the sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 23, 2017 | Televison & Video
Samsung HP-R4252 42 in. Plasma HDTV Logo
186 people viewed this question
Jerry Greenberg
Jerry Greenberg
