Question about HP Officejet Pro L7590 All-in-One InkJet Printer
I put in my memory card and get a message on the printer that there is a memory card error
    Genius:
  • 1,913 Answers
Check your meory card with card reader it is proper working./
aslo check that there is memry card is not full of mremory and virusminfected.
Posted on Dec 30, 2008
Printer error 70
Brother DCP-165C inkjet All-in-One Printer Error Messages
Once you are familiar with the types of errors that can occur while you are using PhotoCapture Center, you can easily identify and troubleshoot any problems.brother-dcp-165c.jpg
Hub is Unusable.
This message will appear if a Hub or USB Flash memory drive with a Hub has been put into the USB direct interface.
Media Error
This message will appear if you put in a memory card that is either bad or not
formatted, or when there is a problem with the media drive. To clear this error, take out the memory card.
No File
This message will appear if you try to access a memory card or USB Flash memory drive in the drive (slot) that does not contain a .JPG file.
Out of Memory
This message will appear if you are working with images that are too large for the machine's memory.
This message will also appear when a memory card or USB Flash memory drive you are using does not have enough available space to scan the documents.
Media is Full.
This message will appear if you are trying to save more than 999 files in a memory card or USB Flash memory drive.
Unusable Device
This message will appear if a USB device or USB Flash memory drive that is not supported has been connected to the USB direct interface (For more information, visit us at http://solutions.brother.com.). This
message can also appear if you connect a broken device to the USB direct interface
Nov 03, 2010 | Brother DCP 165C Compact Color Inkjet...
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
I continue to get this error message on my HP A612.
first check the card to make sure it isn't write protected, if it isn't write protected, put the card into a camera and the camera should fix it
REF:
http://h10032.www1.hp.com/ctg/Manual/c00701123.pdf
Dec 25, 2009 | HP Photosmart A612 InkJet Printer
Sd slot used to read cards, now "memory card error"
i am trying to copy my photos from my 4 GB SD memory card on to my computer through my printer HP PSC 2355 all in one printer. But as soon as i put the card into the slot it turns green and the a couple of minutes later turn Red and flashes and i cannot read it on my computer
Dec 04, 2009 | HP Office Equipment & Supplies
MEMORY CARD ERROR
What photo printer are you using?
It might not be able to read the High Capacity Memory Card. Check the user manual it should say what size and type of memory cards it is compatible with.
Aug 04, 2009 | PNY 4GB Secure Digital High Capacity...
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
HP laser Jet 2840
Try using a different Memory card and see if it reads it, if not you might need to replace the memory card reader.
Oct 26, 2007 | HP LaserJet 2840 Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
256 people viewed this question
Ben Johnson
