Question about Atlus Sticky Balls for PSP
Wireless trackball mouse pointer frequently won't respond
Battery full, range to receiver 6 ft, screen pointer frequently moves 'jerky' motion. The trackball feels sticky, Sometimes won't spin without extra pressure. Has worked fine for a few months and now erratic. Could the trackball need cleaning ??.
Just took it apart and cleaned the ball thanks anyway
Posted on Dec 31, 2008
Ideacentre mouse and keyboard lockup
There are some basic steps that you can take to make sure that your wireless keyboard and mouse have the best chances of working.
First and foremost, replace your batteries.
This is the leading cause of failure. Strong batteries are vital if your wireless keyboard and mouse, including Microsoft, Logitech, and other brands, are to work correctly.
Weak batteries can be frustrating to deal with. Sometimes the mouse or keyboard will work fine, and sometimes they start acting odd.
This is where the jerky and slow motion problems can show up. The problem is that Alkaline batteries can provide plenty of energy at first, even if they are worn down.
After a few minutes or hours of use, however, they lose their capacity and the jerky problems can start up. You may even deal with it, then walk away from the computer for the rest of the day (such as leaving your office).
While you are gone, the batteries regain some of their capacity. The cycle repeats itself until eventually the keyboard or mouse do not work at all.
Another common problem is that the receiver for the wireless keyboard or mouse can be too far away for them to work. I have personally seen cases where the mouse works if used on one side of the mouse pad, and not the other.
This was due to the distance of the mouse from the receiver being too great when on the far side of the mouse pad.
The same can be true of a keyboard.
This will also cause the same jerky motions to a mouse, and missed keys on a keyboard.
The solution to this problem is to move the receiver closer to the keyboard and mouse. If the receiver is of the USB fob type (similar in shape to a USB memory stick) then you can buy a USB extension cable and place the fob closer.
Perhaps placing it next to the monitor would work best. If the receiver has a tendency to fall behind your desk, a small, clear piece of scotch tape will hold it down, and will be one hundred percent removable if you decide to move it later.
If your wireless keyboard or mouse have a desktop receiver, try moving it a little closer.
You may also need to press the "connect" buttons on the receiver and also underneath the keyboard and mouse.
If they have an on/off switch you should turn them on and off.
Hopefully this article will help you to fix your Microsoft wireless keyboard and mouse slow, **** or lockup problems.
If not, check with the technical support and Frequently Asked Questions sections of your manufacturer's support website.
hope this helps
Sep 04, 2012 | Lenovo IdeaCentre Computers & Internet
MOUSE + TRACKBALL DEVICE DRIVERS VARIOURS MANUFACTURES have to buy 2.4ghz wireless devices [apple,mouse,track pad,magic drivers] [os-x mac] [precision:trkball,KB,drivers,input devices,pointers,TRAK] {select device you need info on} [select or type of drivers] (MAC) [free software for KIDs] [encrypted] [trackball pro] [disability information and equipments] [4833drivers+672interface],trkball,touchscreens/ [OS_X, mice,KB, trkball] [mice,trkball,rollers,websites,marble,ft switch] [premeir:mice,KB,joystick,trkball,human interfaces] [cleanable sealed medical KB,touchpad,joysticks,etc..] [kill_kem.exe / setpoint.exe / press ESC+Cancel] [point,Nclick,mouse,trkball,drivers, pointer devices]
on May 08, 2015 | Computers & Internet
After months of good work my mouse stopped working, it has to be very close to the receiver for the pointer to move. New bateries installed, still the same.
Has any new piece of hardware been put in between the trackball and the receiver? Electro-magnetic fields can cause interference. I had a similar problem once - didn't even unplug the receiver, just moved it behind the monitor. It was a big clunky CRT screen and created a huge EM field - huge enough to cause interference with the trackball.
Oct 05, 2010 | Logitech Cordless TrackMan Optical...
Jerky pointer and freezes
Possible solution for that, open the mouse and CLEAN the mouse.
May 06, 2009 | Mouse Systems PC Trackball II
MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Jerky mouse
Try using a different Mouse Pad or surface. This is a cause of jerky and erratic mouse movement.
Hope this is of some help. Bud
Oct 07, 2008 | Logitech Cordless Mouse
Mouse pointer has disappeared
Recalibrate your mouse and transmitter by pressing the button on the transmitter as well as the mouse. Make sure there in a range no more than 30 ft of each other.
Aug 11, 2008 | Microsoft Wireless IntelliMouse Explorer
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
Atlus Sticky Balls for PSP Logo
Top Atlus Video Game Consoles & Games Experts
James Wishart
Are you an Atlus Video Game Console and Game Expert? Answer questions, earn points and help others
