The paper won't feed through. can anyone help?
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
There is nothing stuck in the cover. It actually pulls the paper in about 2 inches and then stops. Do you think it's the rollers?
