Question about GE JKP45 Electric Double Oven
The Oven won't heat up
The self cleaning function was used and now the oven will not heat up. lower oven won't heat up after cleaning cycle. top oven ok.
  • 1 more comment
  • lisa714 Jan 08, 2009
    How much is the element?
    I just used the self clean and now both ovens will not work
  • talleyklotz Jan 22, 2009
    I have a Whirlpool Double Wall oven. I just ran self clean on the bottom oven and now it won't heat up. The fan turns on, but the coils/heating elements (?) won't heat up. Also, the top oven works, the clock, timer and control panels work fine.
    There is one answer that says to replace the 'element' and that removal of the oven is required but the heating element is listed as the coil things at the top and bottom and says it can be replaced with a screw driver to pull them out and rewire new ones.
  • Anonymous Mar 23, 2014
    After a cleaning cycle it won't heat up
I found an answer to this problem at ApppliancePartsPros, from Gene:
http://tinyurl.com/ycydeb7
He was dead on. I've since replaced the fuse for 3 different ovens in my neighborhood. It's a quick and easy fix. I recommend getting a small furniture dolly to tilt the oven out onto so you don't have to use your back at all.
Posted on Mar 26, 2010
  • 3 Answers
Bad luck, you've almost certainly blown the element. On the bright side even with modern 'throw-away' ovens it is often possible to change the element or have in changed (you will need the serial number and google and to take the oven out and dismantle it - not for the novice really.
Posted on Dec 30, 2008
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I ran a cleaning cycle on the lower oven. Now it won't heat
the answer is the thermal sensor, mine has gone bad everytime I clean the oven. Solution, run a fan on the oven while you are self cleaning, this keeps the outside heat away from the unit. Pain to replace the sensor, its in the middle back of the oven, have to pull the whole unit out.
Sep 24, 2009 | Whirlpool RBD306PD Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Self Clean does not work
heatman101
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
GE JKP45 Electric Double Oven Logo
359 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
