Question about Canon PowerShot A560 Digital Camera
How can i reset a canon pc 1256
My camera olfen have : reset a camera, but i don't know how i can do
I just received a Canon Powershot a95 aiaf due to a death in the family. I am able to view photos already taken but every photo I seem to take comes out completely black. I have a canon that is much...
The A95 is actually a very good camera. But this sounds like it might be a defective CCD imager, and is a known defect for your particular model camera. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Aug 23, 2011 | Cameras
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Had my Canon 490 about a year and now the date and time has to be reset every time I turn it on. Is there another backup battery I don;t know about?
Okay .... so I have been having the same problem and called Canon.. Apparantly, there is a time battery in our cameras. It is a CR1220 and when you open up to where your batteries are, you will see it. You can get it out with your finger nail. Hope that helps.
Feb 25, 2011 | Canon PowerShot A490 Digital Camera
My canon camera says a camera error was detected please restart camera now* i don;t quite understand why... help!!!
Hi! As a first course of action please remove the battery and let it sit for atleast 5mins. This should reset the system and may work normally again. Hope this helps and have a good one!
Aug 17, 2010 | Canon PowerShot SD1400 IS IXUS 130...
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Mar 12, 2010 | Canon PowerShot A510 Digital Camera
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
Incompatibility between canon EOS XTi and windows 7
Your problem is that Canon have not yet released a Windows 7 driver for your camera.
You might be able to run the software you have if you set Windows 7 to "compatibility mode". This makes your current software believe that it's running on a pc using an earlier version of Windows.
Feb 18, 2010 | Canon EOS 10D 35mm SLR Camera
Camera not connecting to pc
on your computer go to the control panel and click on scanners and cameras. there u can connect with your camera.
Feb 14, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Trig Identities
Change csc to 1/sin. Find a common denominator and add the two left terms.
1/sin - sin = (1 -sin^2)/sin. Rewrite formula
(1 - sin^2)/sin = cos^2/sin Divide out the /sin.
1 - sin^2 = cos^2 Rearange.
1 = cos^2 + sin^2 Yes, that's true. It's like the Pythagorean formula.
May 22, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Canon PowerShot A560 Digital Camera Logo
1,109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
